Results 1 to 9 of 9
Thread: Fixed my Heat
    Dec 20 2005
    02 Audi A4 1.8tqa
    Stoney Creek, Ontario
    Fixed my Heat
    Hey Guys and Gals,
    A few weeks ago I started a thread talking about the problems I was having with my car. The newest entry on my list has been "no heat" due to clogged heater core. This week I brought it to a shop to have it flushed. I wasn't too optimistic as I've heard there is really only 50% chance this will work. After spending all day with the car the mechanic was able to remove all the junk in the core and bleed the coolant lines to remove all the air. Now the car blows heat right from hell herself. I'm more than pleased as it only cost me $200 instead of the $1000 I was quoted to change the heater core.
    I win...and love my car even more now...thanks for reading
    Mike
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: Fixed my Heat
    Heat is a nice treat as we get closer to Winter, ive lost heat before in other cars, man you dont miss it till its gone.. But i have cold weather package, ill just turn the seat on.
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Dec 20 2005
    02 Audi A4 1.8tqa
    Re: Fixed my Heat
    thats exactly what ive been doing...crank the seats and wear a scarf
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    Re: Fixed my Heat
    damn i think i need to do this to my heater. Cause i've been having issues with my heat on and off too. Just curious, was it absolutely no heat or did it just take a really long time to heat up and not seem to get as hot as you would think "hi" should be? I'm having trouble with option number 2. It takes like 20 minutes for the air to warm up even after the car is warmed up. And the colder it is, the longer it takes.
    Dec 20 2005
    02 Audi A4 1.8tqa
    Re: Fixed my Heat
    you may be in a better situation thatn I was...my car didn't produce any heat...it was just room temperature air regardless if the system was on HI or not...if you want to check for sure touch the inlet and outlet hoses that run to and from your heatercore...they're located beside the battery...if one is cold then your heater core is blocked with either crap or air...try to bleed the coolant lines of all air first and see what it does...let me know
    Mike
    Jul 04 2008
    Seattle, Washington
    Re: Fixed my Heat
    ^^ cool. That's good news to me then. I'll check it out.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Fixed my Heat
    That's weird that it clogged up. The heater core in ours cars is a constant flow system, meaning that the coolant flows thru the heater core all the time if the engine is running. Usually you only have a clogging issue in a car the has a heater control valve and the coolant sits in the core to long and goes bad.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 20 2005
    02 Audi A4 1.8tqa
    Re: Fixed my Heat
    yeah...when the engine is running the inlet is hot but the outlet is cold...really weird...there may have been more air trapped than junk
    Jul 04 2008
    Seattle, Washington
    Re: Fixed my Heat
    ^^ yeah mine is definitely doing the same thing
