baud rate will definitely affect data transfer rate, as baud rate is the physical layer's actual transfer rate.
While there are compression methods to cram more data into the stream, you cannot use them here.
You are transferring 9600 BITS of data per second. that is a max of 1200 bytes of data per second. Great for BBS's during the 1990 to 1993 era, but not so much for any meaningful data. You will lose some to overhead. Each data plot would have like 10 to 20 bytes taken up. Remember this is PER SECOND, so that would explain the lack of 1/100 second intervals. If you get 10 samples across the wire per second, 10 samples would be a perfect world example, at 1/10 second per.
Summary:
9600 too low
Set port baud to 115200 on the laptop, and the program. A disparity can cause lost performance of failed communications.
Or:
Buy an actual VAG cable(USB) and use ECU X
EBAY cables were USB, I thought. If this is the case, simply crank the baud rate up in VAG com, and there is no setting on laptop, as it isn't a serial link.
