Results 1 to 11 of 11
    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    Running wire from cabin to engine bay..
    Where are you guys routing your wires from the engine bay inside the cabin for gauges and such?
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Re: Running wire from cabin to engine bay..
    on mine there was a grommet just to the pass side of the ecu box, but its a tip so i think it would be where the clutch linkage would go, but it was the perfect size for 2 gauge wire :)
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Aug 22 2008
    Central Maryland
    Im new to the audi scene but the center vent boost gauge seems to be pretty popular. How the hell are they getting the wire from the sender to the gauge up in there
    Jan 07 2007
    some people go thru the ecu box, but i have seen it flood before frying everything, you can also go thru the pass side right under the cabin air filter. go poke around with a coat hanger till you find good spot.
    for the vent you just have to cut a little hole into the vent tube, the vents just pop out if you pull on them
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by JaVa View Post
    x2
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    or if your drive by cable you can run a coat hanger through that opening and the wire will come out where your knee bolster is and it is right by everything you need, ignition, fuses etc..
    Jan 07 2007
    Quote Originally Posted by baboom View Post
    so thats what the hole is for :) no throttle cable for me....
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    x3
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Aug 22 2008
    Central Maryland
    Guess I'll have to poke around when Im back home from college for thanksgiving break. Good time to install my new forge dv too. My factory one sounds like a dead duck lol
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    i use the grommet next to the ECU for where the hood cable passes
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Registered Member Two Rings 4BLKRNGS's Avatar
    Oct 22 2008
    Monrovia, MD
    under the steering wheel a little to the right there are 3 posts and one of them is a 12v source i just used that since it saves me the trouble of running multiple wires through the engine bay and for the vacuum line i ran it through the ecu box down and it came out above the gas pedal.
