    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    Another failed APR Snub, with pics (30k miles)
    Another failure of the APR snub mount. I had this one installed for ~30k miles. I did not launch the car while this snub was on..only did regular driving. I knew my snub was going when my shifts started getting more clunky, and the vibration got worse at idle. I checked under the car and found the APR snub LOOSE on the mounting bracket. When i pulled it out, the inside has been eaten away and cracks were starting to form at one edge. I got an Akipol replacement and hope to see more miles out of it. After putting the new snub on, shifts are smooth and gear changes are fluid again. STAY AWAY FROM APR SNUB MOUNTS.
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    Re: Another failed APR Snub, with pics (30k miles)
    man, that's so weak.
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    buy the JHM snub mount. it works
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    I just installed my Apikol earlier... i paid for it monday night about 9ish and it arrived Wednesday afternoon (from apikols website) and talk about impressed!!! That was some great service. I like it so far, and i didnt have to adjust anything when it was installed. Zero Vibration.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Has anyone contacted APR about this issue?
