Results 1 to 40 of 70
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Probably Have a Broken Timing Belt... UGGHGHGHGHGHGH
    Well as you can see my drive today did not even go close to as planned. I didn't even get the first paper served. I was out in the middle of nowhere when all the sudden my car started sounding REALLY bad... like a playing card in a fan bad. So we stopped and shut it down and started thinking... pretty sure the timing belt broke... or jumped... WHICH should not have happened since I just had it replaced about 6K miles ago by a shop here in Spokane. We decided to try and take it apart there to see what was going on but we got part way in and didn't have the right size socket to turn the crank by hand so we decided to just put it back together. SO now I get the fun job of tearing the car apart again to figure out what happened. The worst part about this is that when it broke we had NO cell service... so we ended up hiking around for a while trying to find a house and we couldn't find one... so we ended up hiking up a half mile hill/mountain to get service and called AAA to get a tow.
    I have over an hour of video from this whole adventure that I will post later once I edit it.
    Josh
    SOUND CLIP!!!
    Here is a sound clip. Obviously it's short because we shut it down after trying to see if we could figure out where it's coming from. We couldn't
    http://www.youtube.com/watch?v=CP0FmGLsAw0
    Feb 08 2008
    01' 2.9L GT S4 racecar built for TA/GTS competition
    North Jersey
    Re: Probably Have a Broken Timing Belt... UGGHGHGHGHGHGH
    (trip vidz) please dont, sounds cheezy....j/k sucks man
    Established Member Two Rings ggar015's Avatar
    Sep 24 2008
    2002 A4 3.0 Sport
    oh my...
    Oct 29 2005
    10speed
    San Francisco, CA
    crappy day man sorry
    - Clint
    2000 s4
    Fairfield, CT
    24mm 12point socket. NOW BUY ONE. and you could have taken the rightside upper cover off to see if the belt broke.
    i heart my s4
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Well ... if it is the T-Belt ... I would imagine the shop should cover it, no?
    6k miles is no good
    --Adam
    Have questions? E-mail me.
    Mar 14 2007
    Phoenix Arizona
    Yeah I had a 22mm 12 point for my jetta with me but not the 24mm one. Didn't think I would need it for a while.
    And I hope the shop covers it. I guess we will see.... I am going to take it apart tomorrow.
    Josh
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    if u take it apart.. they can say u fiddled around with it and fucked it up.. don't u think? voiding any responsibility by the shop... i'd take the towing bill and all that.. and make the shop pay.
    Sep 14 2006
    14 GLI
    ^ OP noted he put it all back together. Shop will never know.
    --Adam
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Wow man you should change your name to frimmel2
    You are having almost as many as problems as he did with his. Although I dont see you beating the living tar out of your car like he did. (No hate frimmel even though you exercised the turbo's as much as you did it still should of been more reliable for you )
    That sucks man. The shop better cover it. they must of installed it wrong.
    One thing though. If it jumps even by 1 tooth I thought the valves would hit a piston so I doubt it jumped at all, and if it was still running the timing belt probably isnt broken. But if it sounded that bad, you did the right thing to pull over and shut it off. I woudlnt try starting it at all until you find out for sure its the TB or not. If you bend valves thats thousands of dollars.
    Keep us informed.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Mar 14 2007
    Phoenix Arizona
    Yeah it was a pretty bad noise... I have it on video. I will post it later tonight.
    josh
    Mar 20 2008
    Ottawa, Ontario
    Quote Originally Posted by 1997gtx View Post
    --Adam
    ya then noted he was going to take appart again tomorrow..
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    yuck, hope its not too bad.
    Oct 29 2005
    10speed
    San Francisco, CA
    i dont think your timing belt slipped
    - Clint
    Mar 14 2007
    Phoenix Arizona
    SOUND CLIP!!!
    josh
    Feb 13 2004
    S Ã C, CÃ*
    hope your not another victim from the WM kit :(
    Mar 14 2007
    Phoenix Arizona
    i don't think it caused this... it better not have.
    VIDEO IS UP!
    josh
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    yeah thats not a TB, would vote dropped valve or rod bearning....
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Mar 14 2007
    Phoenix Arizona
    I think it's a rod... there are no misfires at all so i don't think it's a valve.
    Josh
    Jan 07 2007
    it wouldnt run if it was the TB, and sounds like a rod then.
    Mar 14 2007
    Phoenix Arizona
    yeah thats my guess now too.
    Josh
    Sep 14 2006
    14 GLI
    Obviously not the TB ... Sucked up something perhaps ... Rod ... Who knows. All we do know is that a sound like that is never good. Sorry dude.
    --Adam
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    Based on the sound from the video it sounds like the timing belt damper may have lost tension. The noise might be the loose belt bouncing around. You'll have to confirm this by pulling everything apart and seeing if the belt is loose or not.
    I make this prediction because I had my damper fail on my car this summer and the sound was similar. I had done the TB job about 2500 before and one night the noise developed out of nowhere. I pulled everything apart and found the damper had lost tension. I replaced the damper & the timing belt (it got a little chewed up). In my case the belt did not skip a tooth and there was no engine damage.
    For reference, this is video of an AW member's car that had the same problem a few month's ago: http://www.youtube.com/watch?v=NYEmhPLpi3o
    Your noise is a little louder though so I donno.
    770r B5S4 home built & tuned
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Again I stress dont start the car again until you know what it is, yoru just asking for trouble if it does break or skip, or if its a rod or somethign else it could ruin your engine.
    You probably are not, but after seeing the video it just makes me cringe every time I think of you starting the thing thinking something could go pop. Then dead silence
    Mar 14 2007
    Phoenix Arizona
    Yeah the car is not getting started again until whatever is wrong is fixed. I will check out the damper thing tomorrow. Thanks for the heads up.
    Josh
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    were you under boost when this happened? what were the driving conditions?
    if that belt came off or snapped your car wouldnt even start.
    hope you figure it out wihtout too much cost.
    good luck man
    Mar 14 2007
    Phoenix Arizona
    I was going about 10mph on a dirt road. And no i wasn't in boost.
    Josh
    Oct 31 2005
    Ashburn
    Damn that is not good, I've been there before and it sucks- But if you have some coin it just meens a nice upgrade.
    Hope you get it worked out.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Sounds like a rod to me.
    Just so everyone knows, your timing belt COULD be off by one tooth and not bend any valves. Just one, not two.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Nov 10 2008
    S4
    New Jersey
    that sucks hope its not the timing belt
    Sep 14 2006
    14 GLI
    Any posibility of a rock getting sucked in?
    --Adam
    Dec 06 2006
    09 Subaru Outback XT, JD Tractor, EZ Go,
    Middletown, Ohio
    May seem silly, but you did check to make sure that you did not get a stick or something wedged into acc. drive belt. Also check the fan that is attached to the engine to make sure it is not hitting the shroud.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Why did you remove the entire front bumper? You can check the condition of the timing belt simply by removing the upper cover as someone else mentioned.
    Also, if there's a chance it's covered under warranty, I definitely wouldn't be pulling it apart like that, again, as previously mentioned by someone else.
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    going 10 mph bending a rod? hmm, sounds unlikely. spun bearing? checked your fluids? (as stupid as it sounds)
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Registered Member Two Rings
    May 02 2008
    B5 S4...Nogaro cuz its faster
    DC
    this might soudn stupid too but is your radiator fan hitting one of your intercooler pipes...this happened to me and scared the shit outta me
    Feb 08 2008
    Whitestone, NY
    yup, check the dumbest possibilities. you never know
    $4c@b
    WGLYC
    S4SugarHips
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by alosh View Post
    Not a stupid suggestion at all, I dont think. The same thing happened to me many times too. I def think its a valid thing to look at. It almost sounds the same too. CHECK IT.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Mar 14 2007
    Phoenix Arizona
    Quote Originally Posted by tschmale View Post
    Yeah I checked that first before I did anything else and everything was fine. I also checked my oil and that is right where it should be (it just got new oil last weekend too so it's not old).
    The reason I took the front bumper off was because I was going to check and see if the tensioner had broken or come loose. If it had I was going to put it back but I was missing one of my sockets and couldn't get it the rest of the way off.
    Josh
    Mar 14 2007
    Phoenix Arizona
    Quote Originally Posted by CONTROL ONE View Post
    No the car is not under warranty. :(
    And I would rather do the work myself knowing its done right than have a shop screw it up again.
    Josh
    Mar 14 2007
    Phoenix Arizona
    Yeah I checked all the little things first. The oil is fine (didn't see any metal shavings either but I didn't drain any so IDK yet.
    I am going to pull the timing covers off tomorrow and see whats up in that area.
    josh
