Originally Posted by
1997gtx
I never understand why people say the RS4 isn't a good track clutch. MANY stage 3's guy run it, and you can buy two of 'em for the price of the CM.
--Adam
Because it costs a ton of money to pull your trans. And it's a huge PITA if you're doing it yourself. Better to do it once and do it right.
Some people have had luck with the OEM RS4 clutch. But many of them slip at stage 3 power levels. And how much would it suck to have a brand new clutch slip immediately after break in?
At the very least I'd go with a Vast kevlar or vast ceramic setup. Those will hold a lot more power and you sacrifice very little in drivability.
However, I'd personally stay away from any clutch that uses the OEM RS4 pressure plate (which includes all the vast setups). I've personally had too many BS issues with the RS4 PP and have read of countless other issues.
fwiw I've had an OEM RS4 clutch, Vast Kevlar clutch, CM stage 3/4 and a full CM stage 4.
The CM stage 4 with CM lwfw is, by far, my favorite setup. Very smooth, very little, if any, chatter and much lighter pedal than the RS4 clutch. The vast kevlar was very nice as well... but I really don't like that RS4 PP.
