Results 1 to 29 of 29
    Veteran Member Four Rings Dangler's Avatar
    PA
    mk2 tt steering wheel and e-code HID swapped in
    Here are some pics,
    The Head lights are euro non adaptive HID headlights, simple plug and play install. I got the headlights along with the newer kufatec harnesses from performance cafe. i followed this DIY. you'll notice that the head lights have amber corners, this is correct, only till the later models did the euro headlights come cleared. also those are adaptive i believe and require more component install. i actually like the amber corner contrary to most peoples taste. These will compliment the euro tails i have on the way from oempl.us, which have amber turn signals.
    http://forums.audiworld.com/a4b7/msgs/93217.phtml
    and for those that are going from halogen to HID. The vag com setting i used was 00031. this gets rid of the constant on of the turn signals, and shuts off the DRL's. and the high beams will function properly. my halogen settings i had previously had was 00001, which still allows you to use the headlights, but the bi-xenon motors don't work and the DRL's end up your "high beams". search the 20 dollar ebay vag com thread for more info. or if you have an actually ross-tech vagcom like i do, then the optional code list pops up.
    The mk2 tts-line steering wheel, i picked up from dobos here on audizine. in order for this to work 100%, you need to swap the harnesses and re wire a little bit, i will draw up a hand sketch and take a picture, and post up later. drawing in paint is a pain. and to get the paddles to work, all you need to do i change the vag settings.
    also note, the main yellow harness wont fit from the mk2 tt into the steering columns harness, the a4 and tt harnesses may look the same but you'll noticed they are keyed differently. if you try to shave the tt plug to get it to fit. (like the first time i tried to install this), the horn will NOT work nor will the lights on the steering wheel.
    go to the steering wheel module, and go to recode, on the high head ross-tech cable with the new software, it will pop up a coding menu on the side so whatever the code that in your car at the moment, just +1 to the third # from the left. my original code was 02021, the new code 02121. you can do this with the old ross tech software and the ebay cable.
    hope this helps anyone else that attemps the steering wheel install
    F.T.W.L.T.B.D.W.I.C.T.W
    Active Member Two Rings krazykorean's Avatar
    Nov 03 2008
    2007 Audi A4
    Phoenix
    Re: mk2 tt steering wheel and e-code HID swapped in
    Wow that steering wheel is sick =) Good job
    ~Jihan
    Jan 06 2008
    Dacia Sandero
    Arizona
    Looks good man!
    Steering wheel swaps are quite popular nowadays.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Great quality photos! Which camera?
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Looks good. I also like the amber in the headlights, although most don't.
    Do you have any other pictures of the steering wheel from a little further back?
    PA
    canon 30D with canon 50mm 1.8f lense.
    when i get a chance, i'll take a couple more pics.
    Veteran Member Four Rings ElCapitan464's Avatar
    Jul 20 2008
    Orange county
    man that is a sick steering wheel i wish i had the money to buy one, but man urs looks good, where did u pick it up
    GONE: B7 S4
    GONE: B7 A4 stage 2+
    FRRG Southern Ring Member
    PA
    Quote Originally Posted by ElCapitan464 View Post
    dobos100, i think that's his name here on audizine. i got it for 860ish with airbag. good deal for what they typically go for.
    search on ebay. you'll find them there also.
    Senior Member Two Rings Bigswede's Avatar
    Sep 24 2006
    B7 A4 DTM *B7 Avant 3.2-B6 Avant 1,8tsq sold*
    Sweden
    this came out really good.I'm really lovin' the tt wheel ;-)
    Audi A4 B7 DTM Quattro
    Sprintblau...
    Carbonio, carbon enginecover, carbon washerfluid cover, Debadged, Black grille, black trim...
    New Ride http://www.garaget.org/?car=192804
    Old Ride http://www.garaget.org/?car=70366
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Wheel looks great! I want it!
    How are you liking the Podi? Does it block any view?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    PA
    the podi is nice, i'm so used to it now, but yeah it blocks the speedo a bit, depending on your seating position and wheel position, you're view will change. right now i can't see anything below 20mph. which really has no significant impact on my view.
    Nov 24 2007
    Tromsoe, Norway
    ^^ my car doesn't go belowe 50mph....It's on\off
    Senior Member Two Rings dobos100's Avatar
    Dec 13 2007
    los angeles
    I'm glad you are happy with the wheel, and appreciate the mention.
    The pictures look great, with your permission I'd like to use them if I may for the listing.
    Thank you and enjoy.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    awesome pics and sweet steering wheel, nice job
    Jan 04 2008
    Cincinnati, Ohio
    The TT wheel is gorgeous...looks nice man
    PA
    Here are the diagrams to help with the minor rewiring to get the steering wheel to work 100%
    DUH! an Audi
    los angeles, CA
    why cant you just used the a4 harness and not the tt one? would that make it easier?
    PA
    you can't use the a4 harness directly, when you see the harness's side by side you'll see why, some of the plugs are different sizes. its only a matter of swapping leads thats all.
    the TT's air bag has two points that need a ground, hence the two leads on the TT harness. and the plug for the horn on the a4 harness wont fit on the tab on the TT airbag.
    also the main yellow harness looks similar, but its "keyed" differently. so it won't pop into the black receptacle in the steering column.
    when you put the airbags side by side, there are minor differences, that require you to change leads/taps.
    Veteran Member Four Rings TooLow2.0T's Avatar
    Feb 13 2004
    Portland, OR
    I'd love to get that TT wheel. Looks great!
    Current: Tundra Brown 2015 Audi Q3 Prestige Quattro | Black 2013 VW Jetta
    Previous: Brilliant Red 2007 Audi A4 2.0T Quattro 6MT S-Line Titanium
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    audinoob06: The wheel looks great!
    Could you take more pics of it from further away? I wanna see how it flows with the rest of the interior.
    PA
    when i get home from work today, i'll try and take some pics
    Veteran Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    Looks great, thanks for the info.
    2012 Audi TTRS Carbon Package
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Another on that wheel. Stunning!
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    great writeup, I actually just bought the TTS one myself. I have an extra if anyone is interested. It in the classifieds and I'm selling for 700 shipped with the airbag
    PA
    A quick pic with my point and shoot. here you can see how the steering wheel looks against the dashboard.
    Also, not the TID Styling paddle shifter extensions. Just a fun little addition.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    so did you get those from Vivid racing?
    PA
    No..vivid racing sells Agency Power Paddles shifters, which i think look cheap and bulky. And you have to take apart your steering wheel to install.
    The ones i have are made by TID Styling. Which look better, and are a simple stick on install. comes with 3M's VHB (very High Bond) twin-stick tape. as long as you prep the surfaces properly, the adhesion is super super strong.
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    Thanks for the pic. How does the steering wheel feel compared to the originals? Better grip etc?
    PA
    the leather is fresh, so its a bit more grippy. and it feel a bit lighter, but not totally sure, might just be in my head.
