Results 1 to 13 of 13
Thread: N75
    Jan 13 2008
    canada
    N75
    i have a stock S4 and the cel just came on!!N75 p1548
    im going stage 2 +..what should i do??
    witch side is it??
    car work fine??
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: N75
    get a mbc and run it stand alone..Just my thoughts..
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: N75
    No need for stand alone. That's not needed for anything in Stg 2+ territory.
    Just replace the N75, it's not expensive and a simple repair. Running a MBC won't make the CEL go away, and leaving the N75 unhooked or faulty will result in "limp mode" and decreased power.
    MBC is an option, but you will have to bypass the N75 connector w/ ~30ohm resistor.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: N75
    Nice to know there's actually a specific code for the N75 valve. I would just replace it with the Race Version from ECS Tuning. It's only $86.
    That makes my decision to get it as a precautionary measure easy. Just wait until a code is thrown.
    Jul 04 2007
    00 s4
    danbury
    Re: N75
    i have the ecs race n75 on a giac x flash, apr bipipe, intake and forge dv's. works pretty well. holds boost alil better and alil longer. you can def tell a difference. spikes high though, lol
    Veteran Member Four Rings So_NAudi's Avatar
    Jul 11 2008
    Dead Hookers, Kilos of blow and an asston of pokemon cards.
    43.07°N 87.97°W
    Re: N75
    if you replace it, be careful, those things are fragile little devils.
    -Alex
    ¯\_(ツ)_/¯
    Jun 14 2007
    2000 S4
    Connecticut
    Re: N75
    The location of the N75 is in the circle on top left of pic with an arrow pointing to it.
    The other day I made a REALLY fast DIY, but it's all you need to know on how to change it out... Disregard the rest of the picture I was also instructing someone on how to change diverter valves...
    OK READY..
    Removing N75..
    1. Remove Clamp 1 in picture, get pliars, its a bitch to get off pry them together and put it on the Y pipe for now....
    2. Remove Clamp 2 on Mass AirFlow Meter
    3. Pull the clip holding the electrical connection to they N75 off, this will allow you to pull that plug off very easily
    4. Push the n75 towards the firewall... it will be easier to work with
    5. The N75 is shaped like a T, there are 3 hoses going to it. Remove all the hoses, just remember their orientation. One from the left, right and bottom. Have FUN with the Audi ONE time clamps. Struggle a bit, makes you love/hate the car more
    6. Install N75 in the same orientation. Nothing tricky here just use normal clamps, go to home depot get screw clamps small enough to fit on those hoses and tighten them. You MAY want to use dish detergent or something slippery to rub a small bit on the stems of the new N75 so the hoses slip right on...
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: N75
    ^ Nice :)
    Have questions? E-mail me.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: N75
    Quote Originally Posted by 1997gtx View Post
    ^ Nice :)
    lol thanks. you should of seen my post the other day, i used every bit of all my markings on that pic haha
    Jan 13 2008
    canada
    Re: N75
    thank you everybody:P
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: N75
    Correct me if I'm wrong, but wouldn't running a different N75 cause erratic or undesirable behavior if your tune is meant for a different one as they act (spike/hold/etc) differently?
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jun 14 2007
    2000 S4
    Connecticut
    Re: N75
    Quote Originally Posted by Rated S View Post
    it can for sure that's why its best to just get the N75 that came stock with our car. No need for the race valve.
    Jul 04 2007
    00 s4
    danbury
    Re: N75
    ya your right. I got one for dirt cheap and decided to run it anyways
