Thread: faults codes
    Senior Member Three Rings tommy782's Avatar
    Aug 01 2008
    canada
    faults codes
    I scan my car and I found these codes:
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 008 - Implausible Signal - Intermittent
    Last week I install new HID and after some days of utilisation, when I start the car, and I turn the light on, the ABS LIGHT ESP LIGHT AND THE PARKING BRAKE LIGHT flash in the dash and the car doesn't ride good. Iturn off the key and the car is ok.
    whats is the problem?
    thx
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: faults codes
    Just clear the code and see if it comes back. I've had that code before. I haven't tripped it again in a year.
    Aug 01 2008
    canada
    Re: faults codes
    I erase the code and reappear....
    Feb 12 2004
    Everywhere
    Re: faults codes
    I forgot I had that code come on again a couple months ago on my trip to Cali. Stayed on for a couple hundred miles and would not clear (least of my worries). Never had an issue driving with it though. Try disconnecting the battery leads, let it sit for a few, then connect back up and try to clear the code again. Also make sure your battery is charged up fully. Check all associated fuses. Did you disconnect the battery when you were doing the HID work? Make sure ABS is working. Unless you can feel your abs kicking in when it shouldn't it is not something to really worry about IMO, especially since the code is intermittent. I do not think your ABS control module is bad though... If it is you could be looking at a lot of $$$ to replace it. (~$500)
    Aug 01 2008
    canada
    Re: faults codes
    Humm.. no I think I don't disconnect the battery when I do the conversion HID.I try to disconnect the battery and clear the code.. nothing.. but the time of disconnect battery can change something... me I disconnect and I connect immediately..
