Results 1 to 8 of 8
    Established Member Two Rings ecjr173's Avatar
    Aug 08 2008
    05 A4 1.8T S-Line
    Wheel Alignment Question..
    Is a 4 wheel alignment on a quattro a dealer job only or what. I was told by 3 different shops that they could not do it because they have to drop the sub frame and they didnt have the tools to do it. Can an audi specialist mechanic do this job. Any body in the SoCal OC know of a shop that can do this. I really dont want to fork out a grip of $$$$$ at the dealer. Thanks guys....
    05 A4 1.8T S-Line
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Wheel Alignment Question..
    you can have it done elsewhere but the most common way to NOT do it at the dealer is go to some old school place that doesn't put the car on rails meaning it can stay on the ground. I got mine done at the dealer since it was no hassle and it cost me $130
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    To my knowledge most people with newer alignment equipment can do it. I got mine done for $60.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    look for a shop with a machine in the name of "GSP hunter something or other".. it's the most accurate with lazers and shit., i got mine done for 120 or something.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by got boost. View Post
    if it is lowered and your have quattro this is false. On a saturday I went around to see if anyone other than the dealer could do it and 12 shops told me they couldn't do it face to face in a two hour span.
    Aug 08 2008
    05 A4 1.8T S-Line
    Well i do have Quattro and it sits on sport suspension with 19's. On saturday i went to this place called Super Auto Bacs in Stanton, Ca (for those in the O.C.) and they have some newer equipment. Every body says its a dealer job only because you have to drop the sub-frame to adjust the camber and they dont have tools for that. Oh well thanks for the info...
    05 A4 1.8T S-Line
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by ecjr173 View Post
    Take your car to Johnson's Alignment in Torrance...
    Hawthorne near 190th...
    They have been in business since 1945, you will not get a better alignment in SoCal...
    Everything is oldschool there, including a pit to do lowered cars.
    http://johnsonsalignment.com/
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Quote Originally Posted by 400HPA4 View Post
    I brought my car to a REAL oldskool shop that had a projector and mirrors and stuff to do an aligment, My car was pretty low at the time so they used the pit. Came out pretty good.
