Results 1 to 11 of 11
    Sep 08 2008
    2005 A4 1.8QTip
    Williamsburg, Brooklyn
    Nifty vag codes?
    Meeting up with Tomek tomorrow, gonna VAG the windows / locks.
    Anyone know of any other nifty codes / stuff to do while we have the time?
    Registered Member Three Rings nytildie914's Avatar
    Sep 26 2008
    B/B 2003 Audi A4 3.0 Quattro
    Westchester.NY and Naples.FL
    Re: Nifty vag codes?
    Quote Originally Posted by UhOhQuattro View Post
    ok, im gonna get BURNED for this, but ill be the first to admit im a noob and dont have a SUPER amount of knowledge of cars...some, but not much...how exactly do you VAG different things on your car and what exactly are you doing...?
    Veteran Member Three Rings b6a4's Avatar
    Oct 09 2006
    Asheville, NC
    __________________________________________________ __________________________________________________ ____________________
    2001 Audi S4 Avant. Black/Blue Sport. SRM K24 Hybrids. (Totaled)
    2017 Audi Q7 3.0T
    2010 Audi Q7 TDI(sold)
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    you can put it in Canadian mode so the fog lights come on with your driving lights, auto lock at 8 mph ( i think its 8), remove seat belt dinging, ugh thats all i can think of
    Please Drive Right
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    you can change the service interval that shows up when you press the wrench on the instrument cluster. im doing this as soon as i get a hold of a vag com
    Sep 08 2008
    2005 A4 1.8QTip
    For now we just did
    1 press door unlock
    Window unlock / lock while holding button on key
    Auto-lock doors while driving
    Thanks again tomek!
    Veteran Member Four Rings JJPA4SE's Avatar
    Boxes
    Pittsburgh, PA
    you could change the adaptation codes for the MPG computer to make it more accurate. if you do make sure you do a lot of logging on what your actual MPG is before changing it. dont remember how to do it though (search).
    2001.5 S4
    2005 Acura RL - SOLD
    2006 S4 - 25quattro #159 - SOLD
    2005 A4 1.8tqm Ultrasport Avant - SOLD
    2005 A4 1.8tqm Special Edition - SOLD
    Sep 27 2008
    i have vag...how do i get the seat belt dinging to go away? saw a small write up on az about adding some numbers from the options u have to get the correct code, im not sure what thats all about. Any advice would b awesome
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    For those looking for help with VAG-COM codes, check out the following link - Common Diagnostic Procedures. I hope it helps - it certainly helped me out!
    The link further up in the thread is a very informative discussion in regards to logging the B6, but they really never address the more common and elementary questions of service interval resetting, changing service interval periods, automatic locking doors at low speed, key fob modification (removing selective locking), etc.
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Sep 08 2008
    2005 A4 1.8QTip
    I def. want the code to stop that annoying buzz from sounding when I open my door with my headlights on!
    1.8t Quattro Tip
    Your first car is much like your first girlfriend.
    Not that pretty, and slow at times, but you love it anyway.
    Apr 09 2007
    Cary%2C%20NC
    Using the link I provided in my previous post, I was able to successfully deactivate 'selective locking' and activate 'locking via speed'. Whereas I was not successful with changing my service interval from 10,000 miles to 5,000 miles. Following the guide Ross Tech provides, Channel 05 under 17 - Instruments was "Not Available" whereas Channel 02 already had a value of 0 even though I did not reset the reminder. Any ideas as to why this is?
