I'll try to make a long story short. When I bought the car, it had sludge problems. i did a couple AutoRX treatments, everything worked fine. Drove the car for two years. About every 2000 miles after an oil change I hear valve clicking, so thats when I always change the oil.
This last time I went about 3000 miles, and on my way home from work, the Oil Light of Death came on, you know the 3 beeps and the oil can on the display screen on the guage cluster. I was about a half a mile from home, so I drove it easy, didn't boost.
I parked it in the garage for about a week, and finally today I got some autoRX in the mail. I did an oil change, put a mobil 1 filter, and mobile 1 full synthetic 10-40 in it. Also added the autoRX. So then I take it out for a test drive. It's blowing tons of smoke out the exhaust, enough to fill up a parking lot. So I took it back home. Let it idle, very little smoke comes out at idle, but still noticeable. But as soon as I rev it up to about 3-4k rpms smoke starts dumping out. Also I took it for a drive around the block, gave it a little boost, and the turbo doesnt have the same sound as normal. The best way to describe it is a sound you would get from some speakers hooked up to an amp that had a ton of roadnoise/whine.
I'm guessing, well at least hoping its maybe the turbo. It will give me a reason to throw a k-04 on there. But would a bad turbo cause that much smoke? I'm ready to rip out the turbo to check it out. But I would like some of your oppinions on other options. Im hoping its not the motor. At idle and when reved the motor sounds like a champ, no valve ticking or anything like that.
Please chime in with your thoughts and oppionss.
Jason
