Results 1 to 9 of 9
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    Installed the 71r elim kit, now some problems..
    I finished installing the kit i got from eurocode today, and when i started the car, the traction control light stays on, my headlights stay on, my interior lights all stay on...Why is this happening? I got my ecu flashed for the revo 550cc tune and idk what could be causing the car to go crazy like this. Any insight would help, thanks?
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Saint Cloud, Fl
    Re: Installed the 71r elim kit, now some problems..
    thats a good one. Try unhooking your battery then retry
    instagram ------------> low_enforcement
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Make sure you have your radio code first. If you have the stock radio.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Was the battery disconnected for the install? (Should have been when removing and installing the ECU.)
    The traction control light is on because you most likely have to reset the steering level angle sensor. http://www.ross-tech.com/vag-com/car...ringangle.html
    also, do a throttle body alignment for good measure: http://wiki.ross-tech.com/index.php/...Alignment_(TBA)
    Airbag light on too??
    Why your lights stay on is beyond me.
    -Doug
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    the traction light is common any time the battery is disconnected for any length of time
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Aug 22 2004
    Battery seems dead but the fan on the car is running full speed for no reason. It doesnt stop.
    USP CLUB MEMBER #7
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Funny when I got my ECU in after my AWE GT28r install my check engine and traction light were on and they havent gone off in a month now despite the car running brilliantly.
    I will have to try to reset the steering level angle sensor next week and see if that fixes one of the problems.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    Is your battery dead? Take it out and test it. Sometimes when the batt voltage is low (especially after a disconnect/reconnect cycle), it will have enough voltage to drive any already-closed relay circuits, but not enough juice to actuate the relay itself. Also check for a proper ground at the batt terminal.
    Aug 26 2005
    All those symptoms (except the ESP, ABS and ETC warnings, they result from having the batt disconnected,) with the lights and fan malfunctioning, indicate that water has leaked into the ECU box, then dripped from the ECU box and soaked the Central Electric Control Module below the ECU box, under the drivers side dash. The fan running constantly on fast is from water in the ECU box, and the other weird lighting and electrical symptoms are from water soaking the CECM. You must remove all the water from the ECU box, dry thoroughly, The ECU power supply relay may need to be replaced, as well as anything else in the ECU box that got wet. You may be able to save the CECM by removing the module cover and drying the circuit board with a hair dryer, be carefull not to over heat the circuit board, limit the heat to about 100 F. If the driver's side carpet is wet, there could be water in the Comfort/Convienience Control Module box under the driver's side carpet, forward of the driver's seat, that will cause weird symptoms with the remote door locking and alarm functions.
