It was time for new tires last week so i ordered a new set of Pirelli P-Zero Nero M&S tires.
I had them mounted and balanced onto my SLK 55AMG rims, this is where the issues began.
The tires are The rims are
245-40R-18 Rear 18x9
225-40R-18 Front 18x8
Orignally the rims had 245-35R-18s on the rear significantly worn, and there was absolutely no issues
When i got the car back it was vibrating immensely during acceleration, and i could not figure out why. It ends up that they Mounted the passenger side of my car correctly, however on the drivers side they mounted the Rear rim
(18x9) to the front tire (225-40) and put it on the front. At the drivers side rear they mounted the 18x8 with the 245-40. I only drove on these tires for 30 km tops, and had it back at the shop the next day.. needless to say pissed off ... anyways now my car is still vibrating and pulsating during accelerations bad, and starting to get worse. Its even a slight bit rough while off the pedal. Question is, did the shop most likely fuck something up, or is my tire sizing off significantly enough that it is causing issues with my AWD system. If it helps, the probelm is worse while accelerating uphills. Any help would be much appreciated gents.
Regards,
Kidd
