    Apr 15 2008
    Minnesota
    Water Under Battery
    I recently noticed a big puddle of water under my car and after looking under the hood i found an inch of standing water under the battery. Is there a drain somewhere that has just been clogged? Where would it be located?
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    Re: Water Under Battery
    leaves are probably clogging the drains beneath the battery. battery is easy to pull out but heavy to lift
    Aug 06 2008
    Canadia
    if its anything like s4, which it should be, there are drains on the left and right of the battery, about an inch in diameter.
    May 16 2008
    WA
    yup there are drains under the battery and like others have said its most likely just got leaves or crud clogging them, since you are in there and have the cowling off you should also check the drain behind the ecu box, an the one that is above your cabin filter to make sure they are clear as well, could save you from doing the job twice.
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    Definitely two drains in my 96 and 98 B5's; one under the battery pan (must remove battery to clean), and the other directly below the brake booster...have made it a habit to check and give them a spray from the hose once a year. Easier than mopping up the interior if they became clogged.
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
