Originally Posted by
mike-2ptzero
If you guys want I can call up both SB and CM to see if they offer a flywheel/clutch package.
Ive already done this...
I called clutchmaster and they said the single mass flywheel that i have will be available by the end of this year with any clutch you want.
I called Southbend and they said their kit will be available in Jan or Feb...
I guess both companies are waiting on a certain part to be made for both. If you ship our your flywheel to them they can take the piece off yours and put it on the aftermarket single mass set and mail it back. (its what i did)
I paid along the lines of $1450 for the set up plus shipping to cali and back from Mass. A friend of a friend who is a VW tech did the swap for $450. So all together its $1900-2k including shipping.
I haven't heard any clutch chatter quiet yet but i have only put 50 miles on the car so far. The pedal feel is very close to stock. Its not hard to push down at all... wont hurt your leg after a while.
The light weight flywheel is awesome... it seems to pull more easily in 6th gear then ever before.. especially from 40 mph. RPMs drop a little faster then they used to which i'm definitely a fan of. Two thumbs up on this set up!
Also when i had this done i replaced the flywheel bolts.... i've heard they are a one time use only bolt
