Results 1 to 28 of 28
    Senior Member Two Rings Richardesty's Avatar
    Sep 07 2008
    Audi A4 Sline Quattro 2.0 Tdi
    Lincoln, United Kingdom
    B7 Daytime Running lamps upgraded to LED bulbs
    Yep - I finally got round to replacing my PIAA 'Superwhite' single filament DRL bulbs with some leds (fitted with load resistors).....
    Here's a 'during' shot - the PIAA's are on the right
    And then the finished article - again shown here with my 'always on' led strips:
    So now I've fitted the PIAA's to the reverse lamps - one installed here on the left:
    So difficult to shoot - but the PIAA's look so much whiter in the flesh
    I've always said - "One day I'll be able to afford a BMW, and when that day comes I'm gonna buy an Audi"
    Made in Germany - Modified in England
    Registered Member Two Rings (o)o)o)o)'s Avatar
    Oct 19 2008
    '08 B7 A4, '07 BMW 328i
    Re: B7 Daytime Running lamps upgraded to LED bulbs
    no offense but take off the LED strips.
    looks cheap.
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    On my car those lights r the my blinkers .. i could be wrong
    the think the reverse lights are overkill
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    He switched his blinkers and DRLs.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    oh thats what it is ..
    Feb 15 2007
    like the reverse lights! Where did u get them?
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    where did you get said leds?
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Looks good!
    Sep 07 2008
    Quote Originally Posted by eMacPaul View Post
    Sep 07 2008
    Quote Originally Posted by zachf88 View Post
    They're just PIAA Xtreme white Filament 21watt Bulbs - I bought them from online in the uk - but you should be able to get them in the states.
    They're a blue coloured bulb......and are coded H227 - S25 Single 382 Bayonet 12V 21W
    Sep 07 2008
    Quote Originally Posted by Turn10 View Post
    I bought mine from Ebay in the UK - they look VERY similar to these though:
    Item 380079111949 at www.ebay.com
    Veteran Member Three Rings G18's Avatar
    Feb 12 2004
    Quote Originally Posted by Richardesty View Post
    the leds look real nice, i haven't been able to find white ones in any stores around here. do you know what type of resistor is needed?
    Sep 07 2008
    Quote Originally Posted by G18 View Post
    Here's the resistors I used, although I got mine through a uk seller:
    http://www.eautoworks.com/product-Led-33226.htm
    Nov 05 2007
    Oregon
    looks like you've installed some vertical chrome strips on your grille since the older picture. Not usually a fan of those, but I like it here...which is somewhat ironic because I typically don't like the big fishmouth grille design. Somehow I guess it looks better to me this way. Not just being tricked by the camera, am I?
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Any more pics of your DRL's?
    Are those Yellow LED bulbs for your DRL?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Registered Member Two Rings E46HoodRich's Avatar
    Oct 01 2008
    bmw e46 328i
    Miami
    nice!!! is it necessary to use the resistors?
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    after you had installed them did the ecu pick up saying that the lights are out and now you have a bulb with an "X" mark displayed on your cluster?
    ~~ engineered in germany... modified in brooklyn ~~
    Veteran Member Four Rings TH85's Avatar
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    car looks sweet from the front...keep those led strips on..cool lookin
    is that the stock sline grill??
    koni fsd/eibach suspension
    Sep 07 2008
    Quote Originally Posted by artinmoTTion View Post
    Nope - they're 3mm chrome strips.........I got the idea from this
    Sep 07 2008
    Quote Originally Posted by Sly Raskal View Post
    No - they're white.....although they look a bit blue in the above photo!
    Sep 07 2008
    Quote Originally Posted by blackbox619 View Post
    The ECU doesn't recognize any resistance in the LED's within the headlamps, until I installed the load resistors - then it was fine.
    Sep 07 2008
    Quote Originally Posted by E46HoodRich View Post
    You don't have to use resistors on the 'strip led's' - dependant on where you wire them to. In my case they're just wired to a switched live, so they're 'always on'.
    As for the led's in the headlamps - you don't have to use the load resistors, but if you don't then you have to put up with the bulb out warning on the dash
    Sep 07 2008
    Quote Originally Posted by TH85 View Post
    Yes - apart from the 3mm chrome vertical strips
    Sep 07 2008
    Oh - and here's a photo with the stip led's on with the Xenon dipped beam, and my relocated city lights
    Established Member Two Rings Who Needs 8's Avatar
    Aug 01 2008
    2006 A4, 1989 Turbo Trans Am
    Dallas, TX
    Do you notice a difference in brightness when you're backing up at night?
    The reverse light brightness has been the one thing that was better with my old truck compared to the A4. That old truck's reverse lights illuminated everything behind it really well. I wish the A4 would be brighter.
    Sep 07 2008
    Quote Originally Posted by Who Needs 8 View Post
    In truth - only in my mind.....
    I wonder if I could do a HID conversion
    Seriously though - I wired 55Watt H3 bulbs into my reversing lamps, I wonder if our computer system would cope with that?
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    i threw some blue reverse lights like how the new caddilac reverse bulbs look but i get a flashing reverse light that looks like the police. . can someone post a pic of how to install the resistor to the wire?
    Joooe Mamma!
    Sep 07 2008
    Quote Originally Posted by pa4ul View Post
    Is it an led then?
    Here's what a load resistor looks like:
    CONNECTION INSTRUCTIONS: Connect one wire to ground (or ground wire) and the other wire to the positive wire connected to the bulb. You do not have to cut your car's wires. Squeeze splice taps with pliers. Please note Resistors get hot and must be fitted away from any plastic parts.
