Results 1 to 12 of 12
    Registered Member Two Rings
    Nov 02 2008
    Layton, UT
    Is there a FAQ or write up on cleaning the oil pick up line?
    I just changed my oil the other day and a few days later, I got the red oil light on the dash. Oil checked out fine, no weird noises, runs smooth, etc. When I was pulling out the dipstick, I noticed that some of the orange plastic was broken off and am guessing thats whats clogging the oil pick up. Whats the best way to clean out the pick up line? Thanks!
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: Is there a FAQ or write up on cleaning the oil pick up line?
    AFAIK you have to remove the oil pan, which involves supporting the motor with an engine hoist and lowering the subframe a bit for clearance. Search for info on that, good luck!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Nov 02 2008
    Layton, UT
    Is it possible that with another oil change that the plastic piece might come out if that is whats causing the problem? I changed the oil with 5w30 synthetic oil with a oem filter. Any suggestions would help out. Thanks!
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    it's definitely possible that the piece will come out with another oil change...
    i would try this before cleaning the pick up line. that's going to be a pretty serious job, just for cleaning purposes.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by 1_ate_t View Post
    This is not your issue, it is the dealerships...
    DON NOT drive your car, have it towed to the dealer and inspected for oil sludge issues.
    At the minimum they will do a oil flush, maximum is a full motor replacement.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Greg's right. Alot of plastic would have to fall in for it to block the pick up tube.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 26 2005
    There is a wire mesh screen covering the oil pump pickup tube intake, and it is not possible for the few pieces of plastic to block the intake of the pump or reduce the oil supply to the pump enough to cause the low oil pressrure condition and warning alarm. The screen is either plugged with sludge, or there is some other cause for the low oil pressure.
    The oil pressure must be checked using a pressure gage. Audi issued a TSB with instructions on flushing the engine to remove sludge deposits.
    Remember, there is an extended warranty for sludged engine problems.
    Nov 02 2008
    Layton, UT
    Thanks for the tips guys. I did drain and flush the oil today and got about 6 orange pieces that I got cought in a strainer. Taking it into Audi on Monday with my reciepts for oil changes and hopefully they will take care of me.
    Nov 02 2008
    Layton, UT
    Just got back from the dealership. They said I needed to do a power flush first that I have to pay out of my pocket first, than if that doesn't fix the sludge then anything after that would be covered under the TSB. Is $515 for the flush a rip off or worth it for piece of mind?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Bullshit...
    Do not pay them a cent. Low oil pressure may have already caused damage to your motor. This is their problem...make them fix it.
    Jan 31 2008
    Grafton, WI
    I had sludge clog my oil line, cost me $700 to replace it. Don't waste no money on flushing it. And definitely don't drive the car. By the way I took it to an independent shop.
    2005 Infiniti G35 RWD, 6spd Manual, Sport Package
    2002 Audi A4 Quattro, 5 spd. [SOLD]
    Nov 02 2008
    Layton, UT
    The dealer also told me that the flush needed to be done first before they would look into if the pick up tube was plugged then they would pay for it. The car currently has 124k on it and had a flush done around 59k from the dealer. I have almost all the oil change records, too.
