Results 1 to 7 of 7
    Active Member Two Rings cdc's Avatar
    Jan 04 2008
    Menifee, CA
    Does the TIP trans have a overheat sensor?
    My crome shift surround gets really really hot when the car is driven. Can anyone tell me if the Tip transmission has a overheat sensor to stop any damage being done to it?
    Registered Member Two Rings
    Oct 24 2008
    Louisville, Ky
    Re: Does the TIP trans have a overheat sensor?
    The transmission does know it's fluid temp. For the record, it is very difficult to overheat transmission fluid if the fluid is changed, and nothing is broken. Synthetics can go well over 300 degrees without damage. Your heat you are sensing could be transferred from under the car, as well.
    Jan 04 2008
    Menifee, CA
    Ok thanks. The trans seems fine I changed the fluid and filter about 8k miles ago when I did the TC, I must not have put the heat shield and shifter cover under the car back on properly. But its good to know it would let me know if it was overheating.
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Mine gets warm as well.... nothing to worry about I don't think.
    josh
    Jan 04 2008
    Menifee, CA
    josh
    Stupid question. Hot enough you cannot touch it?
    Mar 14 2007
    Phoenix Arizona
    Oh no, not that hot... hot enough to notice it though but I can put my hand on it and keep it there w/out it burning me.
    Josh
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    in the cummer sometimes the chrome (from the sun) gets really hott that you cant touch it but thats not from the tranny...
