Results 1 to 13 of 13
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Odd erratic boost problems
    OK, I'll be the first to admit that I'm a moron when it comes to turbo cars...
    My 01.5 S4 6MT is chipped (by the PO, I don't know what software) and that is the only mod that's done to the car. Just recently I replaced both pre-cat O2's. After that I was getting problems with boosting issues, normally the car would hit about 18 lbs of boost. A little while after the o2 change I was hitting 18ish lbs and the car would buck, a lot (even at half throttle) then it would just drop straight down to 5 lbs and would only boost up to 5 lbs until I shut the car off. After that it would repeat the same thing. (I shut the car off going down the highway with the car in neutral, started it back up and it would hit 18 again, then buck, and then hold at 5 until I shut off again.
    I did some logs tonight when it was only hitting 5, but cant access them ATM because they're on my laptop.
    But I did write down the codes...
    17965 CHarge Pressure Control: Positive deviation
    16684 Random cyl misfire
    16688 Cyl 4 misfire detected
    16689 Cyl 6 misfire detected
    The 4 and 6 misfires are only at idle, and not when the car is under load. BUT when the car is sitting at idle (760 RPM) the load is showing ~18% that seems high to me...
    I'm going to swap the coil packs from 3 >4 and 5 >6 and see if the misfire follows the coils. If it doesn't then I'll go plugs. But I REALLY want the boost issue resolved, I've been reading and doing a bunch of searching tonight in archives and didn't find anything that was like mine... N75, DV's? Something I'm unaware ok? I've got boost leak ruled out because that wouldn't change after the car's been shut off.
    Thanks in advance.
    Join the OhioVW facebook group for gtg, show, and cruise instant updates!
    1998 VW Jetta GLX VR6 | 2001.5 Audi S4 6MT | 1984 VW Jetta GLi | 2004 VW Golf .:R32 | 2001 Audi TT 225 Coupe quattro
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Odd erratic boost problems
    A boost leak would put you in limp mode and cause misfires. I doubt it would be a coil or plug issue. I'd pressure test, including wastegate lines first before ruling out a boost leak. Short of that, test the N75 if you can, maybe borrow a known good one from someone.
    08 S4- Stock SOLD
    Registered Member Two Rings
    Oct 24 2008
    Louisville, Ky
    The new O2s have discovered that you are running lean?
    The differences between the front and (older) rear O2 readings is just wrong?
    try logging actual versus requested boost.
    Jan 12 2008
    Quote Originally Posted by 4RingsCircus View Post
    I did fail readiness on the cat and o2s... I'll do the logging and put up results tomorrow.
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Do you have stock TBB and DV's?
    --Adam
    Have questions? E-mail me.
    Jan 12 2008
    I've got stock everything.
    And the computer with VAG COM is currently getting a gig of pictures uploaded to it via CF card thanks to GF.
    Jan 12 2008
    I failed at logging... I replaced the N75 today with another one, but IDK if the "new" one was good or bad as it was out of a wrecked car... The car will hit ~7 PSI then drop to 5 PSI and won't go any higher than 5 until I restart the car...
    I had a problem this summer where all of the sudden out of the blue the car blew a bit of smoke after I turned off the ignition and let the turbo timer run. But I haven't had any of that since then, is one of my turbo's completely shot? I don't hear any weird noises at all under load.
    I'm going to try to get my hands on a boost leak tester, otherwise I'll have to order the parts and make one myself.
    Jan 12 2008
    Nevermind, found out problem thanks to 10secS4, he had it e-diagnosed in less than 5 mins...
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Well, what was it? And how was it solved?
    Jan 12 2008
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I would also upgrade your dv's if you have the stock dv's. Your asking for turbo failure if those arn't working right.
    Glad you found the problem.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Sep 14 2006
    14 GLI
    LoL. I asked about your TBB and DVs a month ago
    Glad you got your problem fixed, though!
    --Adam
    Jan 12 2008
    Quote Originally Posted by 1997gtx View Post
    --Adam
    You shut your mouth when you're talking to me
    I'm glad I fixed the problem too... Now I just need to get new DV's.
    And brakes on all 4 corners
    And timing belt service
