Results 1 to 10 of 10
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Down Pipe install question
    Finally got a DP to fix my broken flex joint.
    Can I pull the cat and dp out the engine bay together and work on the dp bolts out side of the car?
    Registered Member One Ring DCVING's Avatar
    May 27 2008
    Erie, PA
    Re: Down Pipe install question
    Its been awhile since I changed mine but I think I was able to yank all that up through the engine bay. It's going to be a tight fit though but you should be able to turn it just right to make it work. Good luck.
    Senior Member Two Rings my 1.8t's Avatar
    May 04 2008
    tucson
    when i did my dp i had to unbolt my flex pipe from the cat in the car and that was a b**** but good luck and let me know if you have anymore ?s
    Sep 23 2008
    San Francisco
    Funny you should ask this question, this pic was taken 30mins ago.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If it's a manual trans you can get it out either way. I take mine out from the bottom. I also don't have a Cat either, so that makes a lot more room.
    Tiptronic on the other hand, you have to separate the DP from the cat in the car and pull the DP out the bottom, Cat out the top.
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Its a manual. The flex pipe is totally split through so it shouldn't be an issue. Just getting what is left in the clamp out might be.
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    well since its in the same topic!
    I bought a Borla exhaust for my car and I havent even tried to install it cause it looks pretty complicated any body have any tip on this!
    Should I just separate the cat from the turbo and get a test pipe?
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    Quote Originally Posted by LaserRedKid View Post
    is that piece on the right part of the Audi exhaust to?
    Sep 23 2008
    San Francisco
    No, that is the "new" down pipe for the system, i also have a new HFC, a magnaflow 14815 and a mangaflow resonator ready to put in. That why i took the whole thing down.
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    it went pretty uneventfully. Got the whole thing out the top. But put it back in pieces. dremeled off the clamps and replaced them. Took me a while but I wasn't rushing. Cat bolts were easy. Down pipe bolts were easy enough with the whole thing on the ground and the use of a hammer. If it was in the car removing those bolts would have sucked.
