Results 1 to 13 of 13
    Registered Member Two Rings
    May 19 2008
    Colorado
    Brake pad questions
    So when the time came around for new front pads/rotors, I opted for OEM rotors but decided to get Mintex red brake pads. After the install, the pads were squeaking quite often, but I figured the squeaking would go away within a few days or so since they were brand new. But, the squeaking never went away. I ended up going to a mechanic to do put on the pads because I didn't have time to do it myself; when I questioned him his response simply was that all aftermarket pads squeak..?
    I'm no expert on brakes so I dont know the validity of this response. All I know is my brakes are still squeaking after having them on quite a bit. I did a little research and found out that some aftermarket brake pads will scratch OEM rotors, or they are simply not put on as they should and therefore squeak.
    So, should I get new pads? Take it into an audi performance shop and make sure Mintex pads need to be installed a certain way? Or get OEM pads to match the OEM rotors? OR just say screw it and live with the squeak?
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Re: Brake pad questions
    From what I know, a) your rotors will be fine and b) you may need to apply some (more?) anti-squeal to the backs of the pads.
    Otherwise, you may have to live with a little squeal, and it should be harmless.
    Brilliant Black 2001 S4 - 6MT <3
    Feb 17 2008
    Ottawa Ont.
    my hawks squeal like mad.
    i have to cut new champfers on the leading and trailing edges to get rid of it.
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Never had/have a single problem with my PBR Ceramics...
    Just put them on a week ago.
    Aug 06 2008
    Canadia
    Audi's are prone to squealing when they are all stock, an audi service adviser i know told me they get alot of complaints about it (warranty issue)
    more anti-squeal(let it set for about 5 min before installing too), chamfer the pads, and lube all the sliders, a dab of lube on the (metal backing) side of the inner front pads helps too.
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    I got Hawk Pads and have no squeaking what-so-ever.
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    anti-squeak in the back of the pads should make it go away!!!
    Go pbr ult ceramics next time..i have them on and no problem !!!
    Active Member Two Rings BJARKI's Avatar
    Oct 29 2008
    b5 S4, mk1 tt, 87 gt coupe
    Gresham, OR
    I just did complete brake job on my car and put slotted / crossdrilled rotors on with OEM pads. The shop I use said outside of ceramic they are the only ones that they have found that don't squeek. The pads weren't cheap ($175) for the front but I haven't had any squeaking and they work great.
    May 06 2004
    W124s
    PA
    ALL brakes make noise. Doesn't necessarily mean anything is wrong.. However there are many methods to reducing it... lubing the pad carriers where the pads slide, roughing the surface of the rotor to "break up" any grooves, chamfering the edges of the friction material/ block sand the pads, anti squeal liquid graphite stuff you apply directly on the pads, etc.... Most are only temporary.
    OEM pads are generally pretty good comprimise as far as noise, performance, and dust for most everyday drivers.
    Aside from the occasional squeak here and there, I also have had very good luck w/ PBR ceramic pads. Good performance, decent dust, low noise, but seem to wear rather quickly
    Keep right pass left, it's the law!!
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Quote Originally Posted by quickglx View Post
    What he said... I have Adams crossdrilled/slotted rotors all the way around with Audi pads. I get a ton of brake dust in the front, but the stopping performance at high speeds is astounding. Oh, and the only brake noise I have is the sound of air going though the drilled holes and slots, haha.
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Jun 14 2007
    2000 S4
    Connecticut
    When I had my slotted and drilled rotors installed with my EBC Red Stuff ceramic pads, It screamed, like SCREAMED for 2 weeks almost, now its dead silent.... those 2 weeks were rough it sounded like nails on a chalkboard x 1000
    Aug 30 2007
    nyc
    i put on vast rear pads and am gnna put on vast front in the spring... i just dnt care bout rotors..... (cant afford em right now)
    c5 A6 tip
    this n that
    Aug 03 2008
    Silver S4
    Im currently running on SR Performance vented and cross-drilled rotors and PBR ult ceramic and its great!!! Best purchase i ever made so far ...Crazy stopping power!!! And like NateS4 said ,the only brake noise I have is the sound of air going though the drilled holes and slots....
