Results 1 to 19 of 19
    Oct 16 2008
    South Florida - Ft Lauderdale
    Did it today ...
    After reading a bunch of posts regarding the CC, I finally decided to put the headlights in the stove (and believe me, I was crapping my pants) but everything went well. I did one thing different: because I did not want to open the lens completely, I smashed the orange lens just before the stove stage. Like this, I had to pry and open the headlight just a little bit, without making any mess with the glue, and was able to close it back while it was still warm.
    Then, Oil change, Air Filter, Oilf filter, SRI with Wagcom to reset everything and, a little bath
    and to take care of the 4x4 mode, I have these on their way.
    To be installed next Friday
    Stay tuned and drive safe
    Active Member Two Rings krazykorean's Avatar
    Nov 03 2008
    2007 Audi A4
    Phoenix
    Re: Did it today ...
    Looks good =)
    ~Jihan
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Smart move.....Might try it.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    As someone who just tried this, how hard was it to get the bumper off and back on? I may have the tools laying around, but I'm more worried about that part than the baking.
    Jan 06 2008
    Dacia Sandero
    Arizona
    Clean.
    I would do the CC mod, except I don't think you'll pass inspection in NYS.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Feb 29 2008
    Quote Originally Posted by 4RingRook. View Post
    Clean.
    Does it help if the bulbs blink orange?? (Not sure from the OP's post if he did that, tho)
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    Clean.
    True.. You need a reflector in the front in order for your car to pass inspection. Always good to have a friend as a mechanic tho.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Oct 16 2008
    Quote Originally Posted by B7A4Sport View Post
    Not that bad. I did not even put the car on jacks nor remove the wheels:
    1/ All top and bottom fenders screws are a piece of cake
    2/ 10 mm nuts on the right side = peanuts because you can stick your hand inside the fender and remove and install them by hand.
    3/ 10 mm nuts on the left side = Not that bad with an extension but a bit a pain to reinstall because you can't fish the nut straight. I use a different extension that look like a spring and it became easy.
    4/ When you are done with the mod and reinstall each headlight, do not tight them completely. Apply the final torque once the bumper is back in place.
    5/ Of course, don't mess with the back headlight adjustment or the 2 thingy on each side of the radiator or all the gaps are going to be off.
    All together, it took me 3 hours
    There is couple good DIY posted on the site
    Feb 29 2008
    Awesome, thanks much man - looks great!
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    Looks good. It takes a real man to bake his headlights.. haha..
    Damn, I wish I had the weather you have over there, I woke up today to around 6 inches of snow.
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Easy, there was a DIY I used that pointed out the 4 10MM nuts that attach the bumper. It takes me less than 20 min now, I did not find it necessary to take out the wheel well.
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Oct 16 2008
    Can't wait next week to install the coils
    Sep 13 2008
    SYDNEY
    I thought break the cap too. but wasnt sure that broken part will come out easily through the small gap. Because i dont want to cook inside the oven i was just going to break the amber by screw driver or something from behind through the hole which bulb going in. Will this be work?
    Oct 16 2008
    Quote Originally Posted by tyaos View Post
    I don't think so because the orange lens is made in soft plastic and you are going to end up damaging the chrome inside the headlight
    Jan 06 2008
    Dacia Sandero
    Arizona
    I think in NYS, as long as it will blink orange its okay. But not white.
    Veteran Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    welcome to the cc club!!
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    looks good...ive passed inspection with the cc mod with no problem..didnt go to any place special either?
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Dec 08 2006
    San Francisco, CA
    I don't think the orange lens is a functional reflector. I think NY might be fussy about you painting over the side reflectors. Maybe?
    Jan 06 2008
    Dacia Sandero
    Arizona
    Quote Originally Posted by redhott06 View Post
    Really? That was one of the things holding me back the most to do it!
