Results 1 to 30 of 30
    Nov 07 2008
    2002 A4 Sport 3.0; 2000 Saleen #415
    SE Michigan
    No Heat! This sucks!
    What's up everyone? New S4 owner here. 2001 S4 blk/blk love the car hate freezing in the morning. I've flushed the cooling system, bleed it, checked the flaps and no heat. Coolant temp is 160 degrees on both the inlet and outlet side of the heater core. Seems like alot of others have had this problem going by all the posts here. I give up!!!!!! Gauge reads properly on the dash. Needle stays dead smack in the middle. What else could it be? Blows one burst of warm air when first turned on and then goes cold right away.
    Thanks
    Chris
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Re: No Heat! This sucks!
    weird... maybe heater core is bad? just speculating ... but i wouldn't doubt it to be a bad t-stat... just relaying bad info
    Lurker
    Nov 07 2008
    SE Michigan
    I thought about that too. It seems that it's fixed a lot of problems by people just replacing the t-stat. I'm gonna try to flush just the core on Monday and see if it does anything. If not I think I'm gonna just do the T-stat. I got the car out of Florida so who knows what they did down there. They never need heat.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    i went through two t-stats.. ( three including the original ) before my t-stat problem went away....
    Lurker
    Nov 07 2008
    SE Michigan
    Is the stat a pain in the ass to change? Is there any links that guide you through it? I know its on the passenger side behind the belt cover, but I'm used to domestic cars. I opened the hood on this and S#%t my pants when I saw how crammed everything was.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    AHAHAHAHHAHA oh damn ... you're in for a rude awakening on this one. yeah, it's pretty much behind the engine.. if the timing belt/tensioners and water pump haven't been done yet.. might as well do that too while you're at it
    welcome to the love hate relationship
    Lurker
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    So you guys think it can be the t-stat even if the two hoses going in/out of the core is hot???
    I think it must be some sensor telling the control unit that it is already warm in the car or a sensor telling the control that the air blowing into the car is hot when it is not.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    just speculating... the sensor for in cabin temp.. can be overridden.. which i'm sure he tried.. by simply cranking the interior temp to HI and fans to HI ...
    the other sensor.. you speak of.. i'm not even sure exists.. from my personal experience ( which is limited ) ...
    Lurker
    Jun 05 2008
    00 s4/05 passat wagon
    VAG-COM is your friend. check for faults in address 08.
    Nov 07 2008
    SE Michigan
    Man you guys are quick with replies. A friend of mine has a VAG-COM and I did scan it. Absolutely no codes come up. It reads the temp control and says everything is working fine. Also showed coolant temp was 92 C. Thats equivalent to about 170 F. So I would assume that coolant flow is fine. Hell I don't know what to do. Anyone want a S4? LOL
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    If the needle is pegged in the middle and your temp readings at the hose are correct then the t-stat is probably fine. Does the heater's blower fan work and blow cold air? What happens if you mess with the controls as parker suggested?
    770r B5S4 home built & tuned
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Quote Originally Posted by Crekuc View Post
    i'll give you $5 =)
    Lurker
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    If both of the heater hoses are hot than you are getting heat and it's an in dash electric problem. I would check the heather mode door or your heather control unit.
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Thanks
    Chris
    had the same problem your t stat is stuck in the open position. Does your water temp gauge drop down tot he colder side when you are driving on the highway?>
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jan 03 2008
    Iowa
    Quote Originally Posted by s42k5b View Post
    He stated above that both of heather hoses are hot= T-stat is fine.
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    mine does.. at idle it the temp needle goes to the center, but on the highway ti drops down to about 25%....but then when I stop and let it idle it goes back up to the center....hmmm
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    May 31 2008
    New York
    yep had the same exact problem
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Quote Originally Posted by Unispeed View Post
    lol that's not normal bud =)
    shout out to the local MN s4 though =P
    Lurker
    May 31 2008
    New York
    my bad must have over read that
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    no .. that wasn't OP .. that was unispeed... OP states his is stuck dead center
    Lurker
    May 26 2008
    Riverside, CA
    THAT sounds more like a termostat, in fully open position...
    If it is stuck closed you over-heat, if it is stuck open you over-cool. A working t-stat controls the temp and keep it in the center.
    Feb 22 2007
    Earth
    So you think its a bad thermostat?
    Quote Originally Posted by mrpeterparker View Post
    May 26 2008
    Riverside, CA
    Yes when you are at highway speed your radiator + air will cool the engine more and the t-stat closes to keep the right temp in the engine.
    Feb 22 2007
    Earth
    Will it damage anything if I leave it like this for a while? IDK, I hate the idea of having to tear into it right now.
    Quote Originally Posted by Caddy7 View Post
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    its not exactly good to drive it under operation temperatures.. and itll only get worse once it gets colder out.. have fun trying to keep your heater blowing hot.. esp in MN
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Nov 07 2008
    SE Michigan
    Sorry guys my son had surgery this morning and I've been at the hospital. Anyways, Yeah the controls seem to be working. When you first turn the heat on you get one good blast of warm (not hot) air. Then within seconds it turns cool. I tried to override it turning it all the way up but it never gets warm. It goes really cold like it's supposed to when you drop the temp in the car. Outside gauge is reading 40 degrees and that's what it is here today, so that seems to be ok. About driving on the eway, it stays dead smack in the middle. Also it can idle for a 1/2 hour and never climbs above the middle of the gauge.
    Jun 05 2008
    how's your condition of coolant? open expansion tank cap and look in there. if it looks like someone poop in there, chances are your heater core is clogged.
    Jan 05 2007
    1988 bmw 635csi
    seattle
    dude just flush out your heater core. I'm sure that's the issue. If you're t-stay was stuck open, you would still get heat. It would just take a little longer to heat up. So don't go in the t-star direction. That isn't you problem. Heater cores on these cars clog all the time. Flush it numerous times with some high pressure water and air.
    Nov 07 2008
    SE Michigan
    I'm gonna start with a flush on the heater core this week. I'll let you guys know how it turns out. Coolant condition is good. It's red G12 and looks clean.
    May 26 2008
    Riverside, CA
    Hey, did you ever get heat in your car? What was the problem??
