Results 1 to 37 of 37
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    Is anyone still running NGK copper plugs?
    Has anybody run NGK copper spark plugs at 3,000 to 4,000 miles? I know they tend to foul within those miles.
    Since I currently have 2,786 miles on my spark plugs, should I keep them or change them?
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: Is anyone still running NGK copper plugs?
    I think most people replace them every oil change, so along the lines of 5000 miles. Are you noticing any performance loss, misfires, etc??
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Nov 23 2006
    Soooouuullllll Cal!
    Now that you mention it.... I notice after the car is warm up, theres this small bog like the car wants to shut off.
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    i have almost 10,000 on mine and they still work great. not really sure what the hell you guys are talking about
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Veteran Member Three Rings 80CID's Avatar
    04 A4, 88 RX7 turbo, 12 MDX, 12 Grand Cherokee
    Houston
    Quote Originally Posted by pandaudi View Post
    I replace mine every oil change 5k miles and they always look good still.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    i ran mine until 7K miles once and when i replaced them they looked to be toasted. i love running the NGK's though, at $8 for 4 you can't beat the price. easy to change them out at oil changes as well. my girlfriend's MKV GLI on the other hand is a different story. removing the engine cover to replace them every 5K miles is a b*tch! next time i'm going to get some longer lasting plugs for her...err more-so for me so i don't have to remove that damn cover so often!
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    i've been running these plugs for 30,000 miles! (not the copper ones)
    whatever pieces of shit came with this car. Putting in new ones tomorrow woot.
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    I got the same problem and I have about the same milage on mine. Car's throttle response sux and before the car is full warm it drops below 800rpm and tries to turn off. It's stalled itself 5 times ion the past 3 weeks. Could be my boost and vac leaks though.
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    I usually change mine every oil change, but it's been almost 8k miles on this last set and I haven't noticed any difference really.
    I use BKR6E btw...
    V8 Touareg - 1G TSI AWD - WRB WRX
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    NGK coppers here. Change 'em every oil change and re-gap halfway in between. Smooth as silk.
    My 2004.5 APR Stage 3+ is SOLD
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    same here, I just change them every 5k miles with the oil change. ive got 4k on mine now and they still run great
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    I'm running BKR7E's in my car (one range colder) and love them! They get changed at @5000 miles along with oil, whether they look OK or not. Like somebody said for $8 its a no-brainer.
    To the dude with the idle problem (after warmup) what are you gapping your plugs at? Checked your coils lately?
    My car is a little grumpy UNTIL it warms up, but I think that's an environmental thing with these "colder" plugs. Will probably gap them tighter or put a set of BKR6E's in until Spring...per OldGuy's suggestion.
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Sep 28 2006
    Delaware
    Quote Originally Posted by boy412 View Post
    Gap size is .28...an my coils are brand new...must be an environmental thing then.
    2018 Audi S4 3.0T
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Ive been running the bkr6e plug for 3500 miles and the car is starting to give me problems all of the sudden it wont start right up like it used to and im getting less mpg
    do you guys think the winter blend makes a difference?
    and these bkrse plugs ran way better than the autolite iridium plugs i tried first
    REVO STG 1
    Oct 27 2007
    chicago
    I originally thought the same thing, that the NGK's were cashed. I decided to replace the o2 sensor because I would occasionally get a "response to slow" code. Problem solved, the new sensor fixed the crappy cold throttle response.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Start running FR5DTC's
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 25 2007
    MA
    wondering if my rough idle issue while using BKR7E's is due to the altitude that i'm at? no one else here has a rougher idle with 7E's versus 6E's at Stage 1+ right? i'm gapped at .028 and all four coil packs are new.
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    Quote Originally Posted by dirtybrd View Post
    are these the correct heat range for just a stage 1 revo flash? ive been thinking about trying these next
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    Quote Originally Posted by rxrep View Post
    thats just nonsense!
    03' 1.8T Tiptronic
    Ziza yellow Fogs
    A6 engine mounts
    Feb 17 2008
    I just changed mine recently based off what i've read on here. They looked fine but I changed them anyway but went with autolite 3923s.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Quote Originally Posted by LampyB View Post
    I bet it's happening since it got colder out correct? Run a warmer plug here in the CO winter. I run a very cold plug for this area (FR5DTC) and definitely would not run them if I had to cold start my car in 30deg or under. (My garage stays ~50deg)
    Agreed. Best plug I've found in my testing. http://www.audigeeks.com/forums/index.php?topic=3036.0
    Oct 15 2006
    From a few to one...
    Arlington, VA
    im running bkr6e's, but now im interested in running FR5DTC's...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Feb 12 2004
    Everywhere
    They work well in high HP applications where heat and spark plug blowouts on the top end can be an issue.
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    does anyone know the difference between the bkr6eix and the bkr6eix-11? I really want to change mine out but am not sure which ones to get. I dont really need anything colder since im not tuned.
    Veteran Member Three Rings Hamotee's Avatar
    Oct 30 2005
    Other German Stuff
    Athens,Ga. Clemson,Sc
    Quote Originally Posted by numer24 View Post
    The difference between the two is in size they are pre-gapped from the factory. The -11 means they are pre-gapped at .044 or something similarly huge for our cars. You normally want to start with something pre-gaped nearer to the gap you are shooting for. There is a good link on the subject. I'll see if I can find it.
    How to account for this massive success? Pure luck? Transcendental meditation? Machiavellian manipulation? Aerodynamics? High colonics? We haven't the slightest idea. -P.L. Newman
    Oct 30 2005
    Other German Stuff
    Two good links: One Two
    Veteran Member Three Rings Drew-B6's Avatar
    May 15 2008
    Syracuse, UT
    ok not to change the subject but I am running BKR6E with my APR 1+ with Bosch TT injectors. I don't think it is running very well and when it starts to boost i hear a spark knock (I think maybe, its some kind of cracking noise even worse when it is hot outside). Should I be using BKR7E?
    Drew-
    2013 Audi S4
    Feb 12 2004
    Everywhere
    Quote Originally Posted by Drew-B6 View Post
    You can try but don't be surprised if you have cold startup issues in UT winter, especially if you park your car outside... You should not be getting spark knock with that setup. You need to log to see what is really going on if you think your car is not running optimally. How many miles you have on those 6E's?
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Quote Originally Posted by CO AVANT View Post
    Jordan, in theory the Bosch FR5DTC would work on a 3.0 SC because right now I am running BKR7Es
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Swap 'em every 5k.
    +1
    It's a different car with these in at startup (but once warmed up it's fine) and quite embarrassing with people in the car. I don't care, I'm going back to the 6E in a few miles when I do my oil change. My boost isn't that high that I need to worry about detonation yet anyway.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Feb 12 2004
    Everywhere
    Quote Originally Posted by Maverick View Post
    The FR5DTC's are just a better plug. At least for my application... Logs prove that.
    May 03 2007
    german
    heaven/hell
    ok, i will ask my tuner and try them out(my tune is very sensitive to changes)
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    so it is ok to run the copper ones instead of the pfr6q plugs.... damn, i just spent $40 on theose
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Senior Member Two Rings Samir4486's Avatar
    Jul 02 2008
    04 A4 1.8TQ 6MT
    ATX
    Quote Originally Posted by TurboQuattroPwr View Post
    shouldn't they be gapped at 0.032 which is how they should come out of the box?, thats what i have them at and i haven't had problems at all
    Nov 22 2006
    Quote Originally Posted by Samir4486 View Post
    .032 for stock, .028 for chipped
    2002 A4 TQMS
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    yeah, tighten them up a little if you have any ECU upgrades.
    Feb 12 2004
    Everywhere
    Gapping down didn't help the timing pull when I compared 2 different plugs in the same heat range... I run .032 FR5DTC's with the power levels I'm at. Never had an issue or found another plug with a smaller gap do any better.
