I've scaned my car and there a lot of code.... i dont what they stand for.....
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: AMS 518 F2
Component: 1.8L R4/5VT G03 0002
Coding: 0016701
Shop #: WSC 63351
1 Fault Found:
16985 - Internal Control Module: Memory Check Sum Error
P0601 - 001 - Upper Limit Exceeded
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Controller: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
4 Faults Found:
01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
30-10 - Open or Short to B+ - Intermittent
01842 - Potentiometer/Actuator for Temperature Flap: Right (G221)
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
Address 09: Cent. Elect.
Controller: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
1 Fault Found:
01497 - Bulb for Blinkers: Front Right (M7)
57-00 - Electric Circuit Failure
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63351
1 Fault Found:
Address 17: Instruments
Controller: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 01331
Shop #: WSC 93187
WAUVC58E82A314581 AUZ6Z0B0131808
4 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
07-10 - Signal too Low - Intermittent
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01304 - Radio
49-00 - No Communications
Address 45: Inter. Monitor
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv.
Controller: 8E0 959 433 T
Component: Komfortgerát T5B 0619
Coding: 12044
Shop #: WSC 63351
13 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01581 - Incorrect Component Detected
35-00 - -
01134 - Alarm Horn (H12)
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
00532 - Supply Voltage B+
37-10 - Faulty - Intermittent
01331 - Door Control Module: Driver Side (J386)
01559 - Drivers Door
61-00 - Won't De-Safe
01332 - Door Control Module: Passenger Side (J387)
01560 - Passenger Door
01333 - Door Control Module: Rear Left (J388)
01561 - Left Rear Door
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
End ------------------------------------------------------
