Results 1 to 3 of 3
    Nov 07 2008
    fl
    i nedd help asap plz
    i have a 1995 audi 90 i got water in the motor so you know what type of work i have to do i just need sum suggestions quick or anybody that can help me cause i need it to get back on the road cause money needes to be made but i live lauderhill fl so plz help me
    Account Terminated Four Rings
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    Re: i nedd help asap plz
    Quote Originally Posted by audiboy89 View Post
    i have a 1995 audi 90 i got water in the motor so you know what type of work i have to do i just need sum suggestions quick or anybody that can help me cause i need it to get back on the road cause money needs to be made but i live lauderhill fl so plz help me
    drain your oil, remove your oil filter. take out your spark plugs, take apart your intake and dry it.
    let your engine drain/dry for a few hours,then get some fresh oil, a filter, and plugs in it and you should be ok.
    if it was possible, i would leave the oil drain plug out, and blast compressed air through the intake untill all the oil/water came out of the engine(rest of engine has to be sealed. then put it back together.
    i did the same thing to my coupe quattro a few years ago. its not a tragedy.
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    dude, if ur over heating its probably just your radiator fan if it happens when you sit still, or your thermostat went bad.
    ....you could also be totally screwed and have a water pump failure.
