Results 1 to 22 of 22
    Sep 04 2008
    2004 Audi A4
    Brooklyn NY
    B6 S4 brakes on A4?
    Are the B6 S4 brakes a direct fitment for the B6 A4?
    -I have done a search and all that came up was a DIY for the B5 S4 brakes to a B5 A4
    -Also, will they clear the stock 17"sport wheels?
    --Thanks
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Re: B6 S4 brakes on A4?
    yes they will fit, u will need the rotors pads calipers/carriers
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Three Rings gear_head81's Avatar
    Apr 08 2008
    empty for now
    Lexington, KY
    you might have a problem with wheel fit meant have some spacers ready.
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    Direct swap and your 17" oem sport wheel will clear them no problem.
    IIRC, yoogene was rocking B6S4 brakes with his stockers for a while.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Quote Originally Posted by gear_head81 View Post
    B6 S4 brakes fit fine over almost everything, B5 S4 brakes on the other hand are a problem. Neither one are a problem on OEM sport wheels.
    Doc you don;t need a write up, brakes are brakes, if you are mechanically inclined, it should be a walk in the park. Have some torx bits read, I think T25? and a 7mm allen.
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    I have B6 S4 brake front and rear... They where a direct swap (rotors, carriers and calipers). If you find someone who has a S4 and went BBK then he will probably sell you everything needed. Great stopping power, specially after having the crappy A4 stock brakes. I have used them on my stock USP 18'' wheels with no problem, but I don't know if they will clear 17's since on 18's they seemed pretty tight... Would be good to know if they clear 17's cause I know someone selling them for cheap and I would like them for the track...
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Sep 04 2008
    2004 Audi A4
    Brooklyn NY
    Looks like if you read above you will find that most people agree that they do clear the 17's
    Thanks for everyones input. Seems like a no-brainer.
    Registered Member One Ring bengee23's Avatar
    Oct 04 2008
    '02 A4B6Q 5Speed
    SF Bay Area
    I am interested in doing this upgrade my question is where can I find the caliper carriers to swap out my A4 carriers, with the S4 B6 carriers? Or what caliper carriers will fit?
    Oct 04 2008
    '02 A4B6Q 5Speed
    SF Bay Area
    I have another question about this setup, I own a 2002 B6 A4, so will any B6 S4 year fit my car? I noticed 2002 S4 caliper is different then the 2004 S4 calipers, so does this matter?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    The 02 and down is a B5S4 caliper and is 321x30mm, the 2004 is a B6S4 caliper and up is a 345x30mm.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 04 2008
    '02 A4B6Q 5Speed
    SF Bay Area
    Ok, thanks. Am I better off finding a used set of B5S4 brakes, and buying a rebuild kit for the sills, or buying new calipers? I have been searching, but they all seem to be sold without carriers? What the hell why doe sno body sell just the calipers?
    Established Member Two Rings David3's Avatar
    Jan 23 2012
    Slovenia
    WAKE UP!!! :D
    I have an option of buying S4 B6 brakes... but I'm confused... will they fit on my Audi A4 1,9TDI quattro? Are there some modifications that i must be aware of??
    Veteran Member Three Rings travrach's Avatar
    Apr 13 2012
    Quote Originally Posted by bengee23 View Post
    The B5S4 calipers dont have a extra carrier like many calipers, they are built into the caliper.
    Also note that some said B5S4 calipers will clear 17 OEM sport wheels, mine did not, you will need like a 5mm spacer. B6S4 calipers will clear.
    Jan 23 2012
    Slovenia
    Quote Originally Posted by travrach View Post
    06-28-2009 10:43 AM #11
    bengee23
    Could you help me any faster that this? :D
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by David3 View Post
    WAKE UP!!! :D
    no, they bolt right up
    - Clint
    Jan 23 2012
    Slovenia
    B6 S4 brakes on A4?
    Are you 100% sure? :)
    Sent from my iPhone
    Dec 19 2011
    Colorado Springs
    For the Reference....
    I have B5 S4 HP2 brakes on my B6 (03) A4, with STOCK 17" Sport wheels, No Spacers.
    It's a tight fit, but they do Fit.
    Bout to get into some B6 S4 front's...
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    B6 A4 calipers are different and smaller than S4 calipers. Which means you can't just change the carriers themselves. B7 a4 on the other hand, shares the same b7 and b6 s4 calipers so you can get away by just changing/swapping the carriers.
    It is easier to find the whole assembly themselves than finding the carriers only. But I believe Donovan is currently selling his carriers atm.
    Sent from my iPhone
    ^^ A quick use of the search feature on the B6 will tell you everything about this. It is a direct bolt-on but obviously...you'll need new pads and rotors. New brake dust cover and SS lines are optional.
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Senior Member Three Rings p8nt's Avatar
    Jun 05 2010
    Traverse City
    Can't be done, it will never work.
    Then - 04 DG USP 6MT
    Now - 02 Avus Sliver S6
    Aug 26 2005
    WAKE UP!!! :D
    Yes. No.
    Vorsprung durch Technik
    Oct 29 2005
    10speed
    San Francisco, CA
    B6 S4 brakes on A4?
    You must be the worst searcher ever
    - Clint
