Results 1 to 13 of 13
    Oct 16 2006
    California
    weird revving and rough idle
    It all happened while I almost arrived to work. And now it suffers really rough idle with no CEL.
    If I press and release the gas pedal, sometimes the engine would just go back to rough idle or sometimes it wouldn't go back to idle and keep the revving upto 2000rpm for about 5~10 sec. And then back to rough idle mode
    It started to act like this right after I got off the hwy. I also felt the engine lost the power.
    Can anyone please tell me what's going on? or any similar experience?
    coil pack issue?
    2010 Honda Accord Crosstour EX-L
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Re: weird revving and rough idle
    kinda sounds like it.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    When's the lats time you checked the gap or replaced on your plugs?
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Aug 26 2005
    It's not possible to accurately predict what the problem is, without a diagnostic scan for the relevant trouble codes that will point to the cause of the symptoms. Get a scan and post back the codes.
    Veteran Member Three Rings gear_head81's Avatar
    Apr 08 2008
    empty for now
    Lexington, KY
    its a mis-fire, check your plugs and or do a scan to find out which coil pack is miss firing.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I think in 99% when the coilpack(s) goes bad you get a CEL
    Spark Plugs- maybe
    Running lean= vacuum leak- possibility + but with this kind of misfires you should've had a CEL, unless you drove with that for 5 min or so.
    What about a bad throttle body?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    And yeah, better scan it to see what causes that
    Oct 16 2006
    California
    OK, here is the follow-up:
    I went to the stealer (yeah, I shouldn't go there. But I am in a new neighborhood and all independent Audi shops are too far away from my place). Since there was no CEL, they took 3 hours to figure out the issue: 3 dead coilpacks.
    But both me and stealer have the same question about my car..... how come there wasn't any CEL??? Anyone has a theory about this?
    Moreover, the stealer is STEALER. They want to screw me over by claiming my rear coolant flange is bad and it needs to be replaced. They quote me: $630!
    I paid for the CP fees but for coolant flange ..... forget the stealer, I am heading to indep. audi shop for dat. :(
    Oct 16 2006
    California
    sidenote: time to buy CP and store them in trunk :(
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Did u replace them yourself?
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Where in CA do you live? What dealership did you go to?
    Aug 26 2005
    Quote Originally Posted by a4_boi View Post
    Couple of reasons for no CP related DTCs,
    The coilpacks are not monitored directly by the ECU, The ECU only checks for +Batt VDC is present or too low. The detection of misfires is by the dip in crankshaft angular velocity coincident with the power stroke of the cylinder involved, and the misfire recognition will turn the CEL ON only after the number of misfires exceeds the threshold count.
    The misfire recognition may also be disabled, if the ECU can't perform the Misfire recognition analysis accurately for some reason.
    Nov 22 2006
    ^^^ wow, awesome. I love learning.
    The rear coolant flange is a DIY... a pain in the ars but a DIY nonetheless.
    2002 A4 TQMS
