Whenever the rpms drop does your DV open and close sporadically?
Usually after a flash, things that go bad are as follows:
Coil Packs
Spark plugs
Try switching to new spark plugs first, or regapping your spark plugs to make sure they are all the same. Lower the gap a little bit. Then if that doesn't solve the problem, you should change them out if you haven't already. Try also switching to sparks that are one heat range colder than your current (stock) heat range.
If that doesn't help, then it's probably your coil packs. It's difficult to say which one is going out, especially if you don't have a flashing CEL, but usually Coil 3 is the one that goes out first.
Chances are, you could be experiencing Knock or detonation.
If there's anyway to lower the timing or boost, you should try that too. Do you have access to a vag? Post up your logs, as it will be a better indication as to where your problem is.
Z
