Results 1 to 9 of 9
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Everythings stop on highway!!!
    Yesterday I dove a long trip from Quebec city to Ottawa (450km).It happens 3 times on the cuise control:Set the cruise control @120kmh, It works corectly, sudenly, EPC lights on,ESP lights on, no gaz pedal anymore, speedo and rpm stop working and stop at there last read, So I removed my key and start thecar again and everythings works corectly and It rehappens 2 more time and only on cruise contol...What is that?
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: Everythings stop on highway!!!
    Good question.. I've had this happen before too
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    has never happened but wonder too.
    SweetnLou!
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    wow same thing happened to me a few times... haha asked the same question a while ago but never got a response so good luck!
    two thousand two audi a-four quattro five speed
    May 06 2007
    3.0 quattro
    South of Montreal
    read codes
    99% = brake light switch malfunction
    Jul 10 2008
    Kelowna BC
    Nope i got torque limit exceeded or something like that
    May 01 2008
    Winter
    Quote Originally Posted by chrom View Post
    read codes
    Oh! It's a fact that my right brake light is burned...
    Aug 26 2005
    Quote Originally Posted by davidlizard View Post
    You need to scan the ECU for troube codes, and also the "Freeze frame" info associated with the trouble codes stored, related to any codes associated with the event. Especially with regards to the Brake Light Switch, as "chrom" posted.
    May 01 2008
    Winter
    thank you every ones!
