Results 1 to 4 of 4
Thread: engine temp.
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    Question engine temp.
    so i just bought my car used about a month ago. everything worked just fine when i test drove it, but now my engine temp gauge isnt registering any temperature reading. is there a sensor in the engione compartment that i can replace to see if thats the problem?
    anyone els ehave this problem?
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Re: engine temp.
    It's a pretty common problem. There is a sensor mounted in the back of the head. It is an easy, inexpensive fix. Search for Engine Coolant Sensor and order from one of the online vendors that are all over the site here - ECS, etc.
    It's like $30 or something and just requires removal of a spring clip, popping the sensor out, replacing, and then replacing the clip.
    Registered Member Two Rings Sick_Boy's Avatar
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    Re: engine temp.
    got the same thing with my 01 1.8t gunna be putting in a thermostat when i get my t belt done and if that dosnt fix it then its the sensor
    Oct 25 2006
    Oxford, CT
    Re: engine temp.
    If the temp gauge doesn't register anything, it is not the thermostat - even with a stuck open thermostat, it will come up to temp a little bit, more-so if you sit idling.
