Results 1 to 4 of 4
    Senior Member Two Rings detroittechno's Avatar
    Jul 03 2007
    DETROIT BURBS
    Question Will these wheels fit???????
    Looking at a set of MB CLS wheels 19x9 +38 offset with 255/35/19 wondering if I can fir them on my B5 S4 with rolled fenders??
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Re: Will these wheels fit???????
    Dont quote me, BUT, I think you're going to need an offset somewhere in the 40s, unless I have my figures messed up. I talked to a guy from a local shop here about running 245s on the back, but I'd need new rims, as mine's offset are +32. If I put 245s on there with the rims I have, I'd be rubbing all over the place.
    Just a nugget of info.
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    I think you're going to need spacers to clear the control arms.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    spacers + quite a bit of rolling..
    255s in the front are quite big...
    im having issues with my 18x9s with stretched 235s... but then again im probably closer to +28
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
