Results 1 to 8 of 8
    Senior Member Three Rings ad03avant's Avatar
    Jun 21 2008
    2003 A4 Avant Quattro
    Olympia, WA
    blinking led license plate bulbs and amp
    I just installed an amp this weekend and everything is working great. The system sounds great with no ground loops but all of the sudden my led license plate bulbs that we fine for 6 mos or so are now blinking and occasionally throwing an error in my dash. I recall when I bought the led's that some people were having trouble with them blinking.
    I wonder how many of those had an amp? Any idea's on how to make them stop blinking?
    D
    Andy
    -2003 A4 Avant Quattro
    -APR Stage 2 +, Achtuning Snub, Avic D3, USP Front, S4 blades and bi-xenons, APR stealth, 034 HFC, ASA JH3 18', platinum VMR sport gauge, h-sport sways, ABT springs, Koni sports, Zimmerman sport rotors, Stoptech stage 1
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Re: blinking led license plate bulbs and amp
    Same thing happened to mine. They kept blinking on and off and throwing a bulb out on my dash. I got fed up and bought new ones that worked, being that they're relatively cheap. I have no patience
    Aug 26 2005
    What is the power supply connection for the amp pulling power from? If it's powered from the same circuit as the original amp, the current the amp is pulling is causing the voltage at the LEDs to go below the minimum value voltage. If that is happening the amp is not receiving full voltage either. The above assumes the LEDs are fine with the AMP powered down.
    Jun 21 2008
    Olympia, WA
    No I ran 4 gauge rockford wire back from the battery like it shows in the a4 mods speaker installation. Its grounded behind the rear wagon panel - where its shaped for golf clubs, behind there. Good ground, no back noise or anything.
    Today my left tail light went out too and when I change bulbs to a builb I know is good (tested in another socket) it still doesn't work. No blown fuses. Im worried I somehow fuc%ed my electronics. Im going to wait until tomorrow. No way to power down amp without removing fuse to battery or power wire to amp.
    Ideas?
    New front components going in tomorrow!
    Andy
    Aug 26 2005
    By "blinking", what is that describing, does the intensity of the LEDs vary or do they turn on and off with a regular even, or irregular interval?
    Jun 21 2008
    Olympia, WA
    Only the right one links, regularly and sometimes it will go off for a period of time. I just put my stock ones back in and Im going to test it out. I will most likely be selling this 42 designs versions if anybody wants them. Ill post a classifieds ad soon. Now Ive got to finish this stereo system.
    Andy
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    im pretty sure its just going bad..i dont even have a system and mine started blinking and after a month they went shot..i think its just a coincidence that they are blowing right after your install
    Jun 21 2008
    Olympia, WA
    I dont see how those things could be bad already, they are less than 6 mo old...
    Andy
