Results 1 to 30 of 30
Thread: wot 13:1 afr
    Apr 14 2008
    a4 avant
    marlboro
    wot 13:1 afr
    possible causes of a bad afr before i was hitting 11.5 now im at 13.0 could a bad fuel filter cause this or a bad fuel pump need help immediately
    -vrt-
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: wot 13:1 afr
    Wow....that looks bad......What're the AFRs under all other driving conditions?
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    fine 14.0-15.0 idle and part throttle 12.1 but wot in 3rd goes to 13.0 just did a compression check and was 180 across the board
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: wot 13:1 afr
    does it do it in 4th and 5th as well?
    That's a sign of a fuel pump not pushing enough fuel volume top end. Depending on what fuel pressure you run, and what pump, sometimes you can actually push less volume at higher pressures.
    does it spike to 13.0:1 or does it taper?
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    taper a bit...starts at 12 and makes its way up to 13- i didnt want to push it with it running lean like that...walbro 255 with a 3.0 fpr
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    Re: wot 13:1 afr
    Same 15 psi-16 psi?
    What pump?
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    yea 15lbs walbro 255 intank....side note i havent changed my fuel filter since i bought the car and after putting gas in it it started missing like crazy the previous two fill ups
    -vrt-
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: wot 13:1 afr
    Do you run a maf?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: wot 13:1 afr
    Do you run a maf?
    Iirc he's ME5 so yes... But so suddenly Mike?
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    any thoughts? lol im going to change the filter tomarrow but should i be looking at anything else...this just happend like 20 minutes ago after all day of driving fine...or could my fuel pump be taking a shit
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    bump any input
    -vrt-
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: wot 13:1 afr
    can you extend your gauge so its visible during a pull?
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: wot 13:1 afr
    Oh man I think I'm running into the same issue as you:
    My setup is compleletly different from your but I have the same issue. The above log is a 3rd gear WOT pull at 21-22 psi on a GT2860RS with a stock fuel pump, stock 4 bar fpr and genesis 415cc injectors.
    I'm subscribed to this one because I want to see what solves your issue. What injectors are you running btw?
    Jan 25 2006
    A4 2.0T
    MD
    Re: wot 13:1 afr
    Quote Originally Posted by 1fstavant View Post
    It could be -- you need some logging data -
    Log some maf values
    and
    if you could observe fuel pressure during a boosted pull then you could determine if pump / fuel restriction has any role in this.
    Jul 07 2004
    socal
    Re: wot 13:1 afr
    Quote Originally Posted by 317ssayzarc View Post
    Well if his maf starts reading lower then it should then it will happen really quick.
    Also if his setup is running his maf near its max reading all the time the maf will tend to go bad quickly.
    Jan 25 2006
    A4 2.0T
    MD
    Re: wot 13:1 afr
    He is running a 90mm maf, so I am sure its far far from max... probably ~ 100 g/s +-
    Jul 07 2004
    socal
    Re: wot 13:1 afr
    Quote Originally Posted by Don Supreme View Post
    Well we know how well those work. Plus since the readings are so low all the time, any slight little change in its readings is going to have a huge effect on the afr.
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: wot 13:1 afr
    are you sure you dont have a leak anywhere, my car was doing the same thing I would creep up to 12.8-13.1 while going WOT and I found a small tear in the hose that goes to the FPR.
    Jul 07 2004
    socal
    Re: wot 13:1 afr
    That could be another cause, he might also want to recalibrate his wide band setup if he can since the wide band 02's tend to read leaner as they get older.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: wot 13:1 afr
    Quote Originally Posted by AudiRacerS4 View Post
    I think this is a strong candidate, considering you had everything apart and maybe things loosened up after breaking her in a bit.
    I do however think Fuel Pump and Fuel Filter being OEM and original may have a huge factor as well. These are the preventative and neccesary maintence/upgrade items to tackle with these cars and the mileage they have.
    Jan 25 2006
    A4 2.0T
    MD
    Re: wot 13:1 afr
    Quote Originally Posted by bassed View Post
    I do however thing Fuel Pump and Fuel Filter being OEM and original may have a huge factor as well. These are the preventative and neccesary maintence/upgrade items to tackle with these cars and the mileage they have.
    He has a walbro fuel pump.
    Sep 24 2005
    always in design
    Re: wot 13:1 afr
    That was directed at Chris, I should have clarified that.
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    walbro is getting changed out on monday for another walbro...after a fill up it will start studdering at idle which from several sources is what happens when a fuel pump starts losing pressure...but my maf readings are the same and its new so i know thats not the problem...
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    fuel pump was the culprit...misfires due to plugs gapd wrong now im gonna do another comp check idk if its me or my mounts but it sounds wrong so ill find out
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    Re: wot 13:1 afr
    What sounds wrong.
    Apr 10 2007
    Eastern PA
    Re: wot 13:1 afr
    :-) I knew what you meant.
    I'm going to get a replacement fuel filter + pump shortly.
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    um idk it sounded wierd but i think it was my fmic vibrating around...love and hate these mounts...love and hate this car another 300 on top of everthing to get it running ok
    -vrt-
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    Re: wot 13:1 afr
    i am having the same problems as well. afr is good everywhere but wot. I was thinking more along the lines of a boost leak but i am on a stock fuel pump, so who knows.
    ::2002 S6
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Re: wot 13:1 afr
    So you got another fuel pump right?? Now that you switched it out are you're afr's back to 11.5? Im wondering because my car has the exact same problem.
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Apr 14 2008
    a4 avant
    marlboro
    Re: wot 13:1 afr
    nope not at all...im putting a new fpr on it tomarrow hopefully tht solves it but im worried im destroyin my motor fin with it...
    before when id loosen the gas cap id hear air his out...now no air so im assuming the diaphram went sour and at idle holding the pressure till it gets to great at wot and sends it back into the return line which is why it drops to 11.8 and then starts climing up again
    -vrt-
