Results 1 to 4 of 4
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    OK, I'm officially for sale.....
    Have my eye on a local Stage 3 and am selling my Stage 2+........I know its a shitty market right now, but whatever......I need to go stage 3 one way or another!!
    Info:
    Early 2000 aluminum uprights 6-speed, black on white, cold weather, NO BOSE. LOW MILEAGE, 60,447!!! Owned for half of its life, purchased back in early 2005 from a young man who only owned it for 3 months, was moving to DT Chicago and knew he couldn't keep it there. Original owner was an older couple from New Mexico that bought it brand new and used it as a weekend car, sold it in late 2004. Carmax then shipped it to one of their stores in Chicago where the younger gentleman bought it.
    I have extensive records on this car! Almost every documentation of a repair, except for those done in 2005, which consisted of the secondary headlight washer pump failing and a green sensor (I think the after-run fan sensor) failed.
    ALL BRAND NEW CA'S
    BRAND NEW OUTER CV BOOTS PASSENGER & DRIVERS SIDE, BRAND NEW OUTER CV JOINT DRIVERS SIDE
    BRAND NEW THROTTLE BODY
    NEW BALLAST AND BULB PASSENGER SIDE HEADLIGHT
    NEW REBUILT DRIVE SHAFT @56K
    FUEL FILTER AND SPARK PLUGS DONE @ 55K
    MAF REPLACED @46K when TBB ripped, replaced w/ Samco
    NEW WINDOW REGULATOR @ 44K rear passenger
    All work done either by VAST or reputable Indy shop in Holland, MI Euro Tech.
    Mods:
    GIAC X w/ Pump 93 & Race file tweaked by VAST w/ MBC
    ASP Tru-dual 89mm
    Stoptech 332 BBK (black) w/ rear slotted rotors and SS brake lines....2 sets of pads for the 332, Carbotech Bobcats (installed) and Hawk HP+ (comes w/ kit)
    Piggie DP's from Tony@EPL w/ VAST CELiminators
    B&M Short shifter w/ JHM weighted shift knob
    Startup Racing Vogtland GT Coilovers
    Startup Racing pedals w/ dead pedal
    ASP TSB (Drivetrain stabilizer)
    RS4 Grill
    Front bumper modified for "RS4 look" middle portion still needs to be finished
    Podi boost gauge
    Samco TBB and F-Hose
    710N Diverter Valves
    Rear fog light mod (so it doesn't look like a light is out)
    18" ASA JH3 wheels wrapped in 18/40/235 Eagle F-1 All Season rubber (sorry, don't have stock wheels)
    All-weather rubber floor mats
    I'm sure there are other little odds and ends mods I am forgetting, I also have records of when all mods were done, just ask.
    THE BAD:
    Not all S4's are perfect, and neither is mine, so here is the history of the bad.
    Got scuffed while parked outside of work and there is a scuff mark on the passenger outer-side of rear bumper
    Front Bumper is cracked in several spots, but is not noticeable from a distance (ie no chunks are missing, it is repairable)
    CEL comes on occassionally, ALWAYS W/ THE SAME CODE: 16805 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold. Shop says the cat converter needs to be replaced, but says it is covered on any car that is less than 8 years old or 70,000 miles.
    Airbag light is also on, the wiring harness under front passenger seat is fried, so the light will keep coming up when cleared out.
    Body shape of paint, ect. I would give 8.5 out of 10, mainly due to the front and rear bumpers
    Interior is 9.5 out of 10, not a full 10 because one side bolster on drivers side seat is starting to collapse. Leather in great shape for being onyx!!
    Asking $16,000 obo
    I have stock parts for some of the mods, so if you would like them swapped, that is fine.
    This car has been my baby and has been driving in only one winter! I have a DD so I have been keeping the miles low so I can save it once I go Stage 3, but my finances now dictate otherwise!
    Either PM or call my cell, Name is Ryan 616-914-1326
    Please don't ask for pics, I will post them later 2nite, thanx guys!!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Veteran Member Three Rings slmds4's Avatar
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    Re: OK, I'm officially for sale.....
    Sounds sweet, do it.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Thats hiiiiiiiiiiiiiiigh. Its not a stage 3. Sounds like you've got some nice mods but the big ones are still missing (turbos and fueling).
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Please use the classifieds, thanks.
    Greg - Moderator
    WWW.ACTLSUB9.COM
