Results 1 to 16 of 16
    Senior Member Two Rings wezlo's Avatar
    Dec 04 2007
    2006 Audi A4 6-speed, 2004 Audi S4 Avant
    New Jersey
    Boost or Vac leak sounds? HELP (Video Inside)
    So ive been at dealers and they tell me they dont know what the sound is, so i desided to post it. When u rev the car up and the revs drop you here a hiss or kinda a loud rattle. I have a forge DV and this sound was happening before i installed it thought that would cure the problem. I dont know why it would be the pcv because i can get the oil cap off with out a problem. So if anybody could help me out and tell me what the hell this is because it isnt normal.
    Also my boost tends to drop from a 18 hold as soon as i hit 5500rpm maybe this is the leak as well? Listen to the whole video as you can hear it alot towards the end
    http://www.youtube.com/watch?v=a-_zgH4mtXs
    Please Help
    Thank You
    Dec 04 2007
    New Jersey
    Re: Boost or Vac leak sounds? HELP (Video Inside)
    bummmp help
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    Would it be your intake? Cuz I don't think you would be boosting to 18 if it was a boost/vacuum leak.
    And yes boost dropping off at 5500 is normal.
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Dec 04 2007
    New Jersey
    no im tuned by apr its not the intake
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    sounds like the wastegate decompressing to me... i could be wrong though.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Dec 04 2007
    New Jersey
    doess anybody have the same sounds on their car?
    Registered Member Two Rings b7ftw's Avatar
    Aug 06 2008
    2005.5 B7 A4 2.0t 6MT
    Phoenix, AZ (Tukee)
    WTF was that sound when you turned off the engine??? i'd worry about that more then your DV leaking (which you should take to the dealership and have replaced, assuming you are still under warantee, if not upgrade to forge DV)
    Last edited by b7ftw; 11-06-2008 at 07:48 PM. Reason: nevermind... didnt read you already have forge DV... id check the settings on that...
    Dec 04 2007
    New Jersey
    thats what im talking about when i turn it off as well and i already have the forge dv
    Aug 06 2008
    Phoenix, AZ (Tukee)
    i personally use a stock DV, never had the need to replace it (yet, knock on wood)...
    does the forge DV come with different springs or something is adjustable or something.... i'd check that out make sure that is all proper...
    Last edited by b7ftw; 11-06-2008 at 07:55 PM. Reason: PS - a shop should be able to do a vacuum check, might also be helpfull
    Dec 04 2007
    New Jersey
    it was making this sounds before i replaced the valve
    Apr 15 2008
    Reston
    sounds are effing hard to diagnose, i would take it in to the dealership and see what they say.. that sound at the very end isnt one im familiar with.
    *SOLD*
    StreetTunedTV.com
    Dec 04 2007
    New Jersey
    ahh how am i gonna find this out
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Check your DV, PCV, and have the car boost pressure tested. The car might by trying to compensate for a leak and still boost the same, but the turbo is going to be working double time.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Dec 04 2007
    New Jersey
    shit this is nuts ive been looking all over for a fix and i cant find it. i have no idea where its coming from
    Oct 14 2006
    MK6 Jetta
    South,FL
    I think I hear what you mean. Its like a ratchet clicking noise.
    That is your fuel pump and came lobe. A friends GTI used to do that same noise, until his fuel pump and came lobe went bust.
    -EI AL CAI.
    -Driver Mod.
    Dec 04 2007
    New Jersey
    sounds like apr fuel pump is a good buy :)
