Results 1 to 12 of 12
Thread: Normal timing?
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Normal timing?
    What is normal timing under boost for these cars? The threads I've seen showing timing logs seem really low, but I'm also used to dealing with lower compression in a turbo engine.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Normal timing?
    (again i ask) total timing or timing pull?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: Normal timing?
    total timing btdc.
    For instance, on my safe tune I run 24 degrees btdc on pump and 28 on race gas.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Normal timing?
    Quote Originally Posted by pit viper View Post
    total timing btdc.
    yah right. please show me logs to prove that^
    you must be at like 5 psi or some shit.
    a good timing curve under high boost is anything over 15 degrees imo. 28 would be fanmuthafuckintastic. maybe you live in the polar ice caps where the air is sub zero?
    Veteran Member Three Rings slammed_nogaro's Avatar
    May 10 2007
    CHICAGO
    Re: Normal timing?
    i run about 30 on race gas...;)
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: Normal timing?
    Quote Originally Posted by ThirdStrike View Post
    Sorry, should have specified. This is in my other car, 2003 SRT-4. I just picked up a 2000 A6 2.7 a couple months ago, and am in the process of building it up.
    The stock compression on an SRT-4 is 8.0:1. And believe me, I wish we had a good logging solution available for that car.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Normal timing?
    well thankfully VAG has a damn good logging solution. its called VAG-COM. log
    and tell / show us what you see for pull and total timing, and at what boost level youre running.
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: Normal timing?
    Just picked one up the other day, still in the process of figuring out how to use it.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Normal timing?
    as in you downloaded the software and are using a laptop?
    http://dieselinside.com/howto/vagcom/log.htm
    log groups 011, 115, and 003
    http://www.ross-tech.com/vag-com/m_blocks/index.html
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Re: Normal timing?
    still on the freeware, as I figured I wouldn't have time to play til this weekend, at which point I'll download the good stuff.
    Thanks for the link. :)
    Jul 06 2005
    Re: Normal timing?
    VAG-com is terrible for data logging. If you're serious about collecting data, get ECUx.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Normal timing?
    Quote Originally Posted by Shomegrown View Post
    :yawn: as youre right about ecux youre wrong about vag-com. it does the job.
