Results 1 to 4 of 4
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    How would you fix this?
    Hey, i my audi about a month ago. its a cpo 05.5 a4. the trim piece above the ignition is pealing back. its something small but it bothers the crap out of me. how would ya'll fix that? i dont want sloppy glue all over the place. sorry for the burry pics.
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Re: How would you fix this?
    Glue....maybe double sided tape, but that prob wouldn't hold. Just peel it back use some epoxy and make sure you don't get any on anything that's visible.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    if it's a cpo take it to the dealer and have them replace it...
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    to me that looks like the peice that is under the steering wheel. there are 3 screws that hole it in place. 1 in the fuse box, 2 under by the pedals. they are 8mm socket screws. i would undo those and try and put it back in place.
    The usual things!!
    Resistor Install
