1. I find that first and third gear are kind of hard to get into...like, you have to really push it...especially first. Sometimes it will slide right in, but other times it's harder (that's what she said). So...anything I should be concerned about?
This gets smoother with time, but I can't say I ever thought the problem was significant.
2. 5w 40 I image...fully synthetic...but, I noticed it's about a qt low...do RS4's burn a little oil? Oil change was done a few months ago....and, it was driven 1200 straight miles for delivery...already bought the oil, just wondering if that's something I should be aware of.
My RS4 has never burned oil. Part of this is the break-in. You need to really let the car experience higher rpms (within the recommended limits) and then allow a lot of engine braking from high rpms. This will allow the piston rings to properly seal.
3. Lithium battery. Is it true you can use a lithium battery and save ~40lbs? Just curious...saw one comment on it...
Not sure about this, but there is a downside. The heavy battery placed low and in the rear does a lot to help weight distribution in the car to aid handling. On the other hand, saving 40lbs in a 4000lb car makes very little change in power-to-weight ratio.
4. Brake Dust...Holy shit. Anyone recommend some good pads? FUCK.
Yes. Ferrodo and Porterfield are popular aftermarket choices
5. Sprint Blue..considering powder coating black...I think it will look hot..any thoughts?
I assume you are talking about the wheels. It may look acceptable if you also paint the mirrors and trim, otherwise don't do it. Won't look as "put together". The painted wheels will look like an obvious afterthought and not like part of an integrated package. With Sprint Blue, will look a little ricey IMO.
6. Headlights...should you always use "auto?" lol..didn't seem to turn on unless I used that.
Not sure what you are talking about. My headlights work fine in all modes. Auto won't allow fog light use.
7. K&N filter...considering...recommended by anyone?
You can do it, but why. You risk getting oil on the MAF, and there is no power to be gained whatsoever. Spend the money on a nice Audi sweatshirt from the Audi Collection catalog.
Thanks...I feel like a newb again...
You're welcome, and you are, aren't you?
