Originally Posted by
dextrek
BTW, B6buckeye was mentioning about Big injector file...what exactly is a big injector file? Is it just the big injectors w/o the turbo upgrade? Can you elaborate on that?
the big injector file is APR stage 1+, GIAC FX or Revo Stage 2 (i think that is all correct nomenclature). it is the bigger injectors without the upgraded turbo - you keep the k03. it will cost you $200 to upgrade the software from stage 1 to 1+ from APR plus the cost of bigger injectors. if you are thinking about that, i HIGHLY recommend that you search on here for "APR lean". you will see that there are a lot of us with problems with that and/or their k04 programming.
the alternative is to switch programming to GIAC or Revo, but then you are back to square one - you have to pony up $500 for the stage 1 programming and another $200 for their respective big injector programs. so, in all you're looking at another $700 plus the cost of injectors.
to any of the above scenarios you can add a k04 turbo to your existing bigger injectors and get the k04 programming from whichever tuner for another $200 plus the cost of the turbo and install.
at that point (or really at stage 1+) you need to add an exhaust and a FMIC. this will help you breathe better and keep your power run after run. brakes & suspensions upgrades are recommended too to control the increased power.
from there it is BT and BAT. Revo is the likely winner here with GTRS on up.
sorry to be so long winded, but that will give you an idea of what you're looking at on your upgrade path. my advice is decide what turbo setup you ultimately want (and on what car) and go that route.
if i had the money back that i spent on the k04, the k04 install and the wild goose chase that i'm on trying to fix the lean codes with this APR software; i could've just gone right to the GTRS setup with Revo and been happy the whole time. learn from us. oh, and go ahead and put that setup on the B6. you'll enjoy your existing car for awhile & then you can step up to a B7 S4 or a B8 A4 and go BT on it.
