I have a 98 AEB passat - KO4 with some other odds and ends. I have been working on pressurizing my system to listen for a boost leak in the engine bay.
So i couldn’t find a tennis ball and it was too late to go somewhere to build the boost leak tester soooo i hooked up the good ol dry vac and it seemed to work. I only left it on for about 10-15second intervals.
I am using the following link as reference:
http://www.passatworld.com/forums/sh...ght=PCV+system
When i pressurize the system i can hear and feel the air coming out the PCV valve and or breather hose. I am going to replace the 4 check valves since im there and the PCV and the breather hose.
is it possible to loose boost pressure from this situation i described above?
Checked the DV, 2 vacuum tubes, hoses to the boost gauge and going to check the plugs tonite and make sure they are gapped properly. Im only boosting to around 15lbs in 1st gear..and in higher gears i hit around 17lbs. When i had the KO4 turbo with the KO3 software i was boosting at 17lbs in 1st gear & higher boost in the higher RPMs....
Neuspeeds site said their KO4 kit boost to 15lbs but i have read and had conversations with people that spike to around 19lbs and then it settles down a litttle. I know the boost dies fast after 5k but it seems like i hold a steady 15 no problem but it only holds to around 10lbs as i get in the higher rpms......
thanks in advance
