Results 1 to 32 of 32
    Registered User Four Rings Dion@Achtuning's Avatar
    Jul 01 2008
    ACHTUN!NG | B6/B7 STaSIS Streetsport Coilovers - FREE SHIPPING!!
    The STaSIS Streetsport Suspension is ACHTUN!NG's most popular coil-over setup and we're offering FREE SHIPPING so even more of you can get in on the deal! This kit is by far the best "bang-for-buck" coil-over kit on the market and offers superior ride quality and comfort despite its performance characteristics.
    List price: $1269.00 | *
    These are in-stock, ready to ship!! Click on the image above to be directed to our website for online purchasing or call toll-free - 877.722.4886.
    ... The details for those who like reading. :D
    STaSIS Street Sport suspension kits are designed specifically for each Audi model and configuration. The ride will feel similar to the factory Audi suspension but with more control. In addition to the comfortable ride the Stasis Streetsport coilover kit will stiffen the suspension just enough to improve the steering response and minimize body roll. The spring rate is chosen for your vehicle and driving use. The dampers are custom valved to match the spring rate. This allows STaSIS to provide the quickest reacting suspension available without the harshness often experienced in mismatched systems. The STaSIS Street Sport suspension kit includes the following components:
    • KONI Cadmium Plated, Adjustable Dampers
    • Koni Progressive Springs
    • UHMWPE Spring Perch Bearings
    Many spring and shock combinations lower the car more than most drivers want. Spring and shock combinations are rarely designed to work in concert with the rest of the suspension and thus make for poor handling and ride quality. The STaSIS Street Sport Coilovers give you the ability to choose where you want the ride height to be while giving you the damping control you need.
    KONI dampers are used in the STaSIS Street Sport line. These are twin-tube dampers featuring KONI's Sport valving. Additional features include a corrosion resistant cadmium plated damper body (when threaded), damping adjustability and height adjustability. Rebound is adjustable while the damper is off of the car. STaSIS sets the rebound for these dampers based on countless hours of testing. Most customers find that changing the settings after installation isn't necessary. The UHMW perch bearing makes for easy adjustments by decreasing the friction between the perch and spring.
    Rear dampers feature the same performance as the front dampers.
    Note:
    The rear suspension of of many Audi and Volkswagen vehicles uses a seperate perch for the spring. Due to this design a "true" coilover is not possible in the rear of those vehicles however an adjustable perch is included for height adjustability.
    * Offer good while current supplies last.
    Jul 01 2008
    Re: ACHTUN!NG | B6/B7 STaSIS Streetsport Coilovers - FREE SHIPPING!!
    Jul 01 2008
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Is there a way to make the ride stiffer/ firmer, then to make it softer? Like a screw to adjust the pressure to dampen the suspension?
    Feb 17 2008
    Are they easy to adjust once installed?
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Quote Originally Posted by Mike02A4 View Post
    The fronts are easy, the rears require dropping the subframe.
    Feb 17 2008
    How much of a drop is the stock setting? I definatly don't want a slammed look, especially for my daily driver on NY roads. Big improvement in handling??
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Jul 01 2008
    Quote Originally Posted by 3.0L AUDI A4 View Post
    These are damping adjustable - STaSIS just pre-sets them for optimum daily driving and the occasional track use or spirited drive. You can certainly firm them up some if you want...
    As mentioned above, the rear is more difficult then the fronts as you do need to drop the sub-frame to even access the spring perch to adjust height. You have to go as far as removing the rear shocks if you want to change the damping settings as well.
    Not sure what you mean by "stock setting" but the coils at their highest point is roughly an inch lower than stock. But "an inch lower than stock" is subject to interpetation as Audi has several different height variations with stock springs.
    Feb 17 2008
    When I said stock setting, I meant the pre adjustment from the factory. I was just wondering if its 'slammed' with the pre adjustment. I am hoping not..It sounds as if they're adjusted for daily driving..
    Oct 29 2005
    10speed
    San Francisco, CA
    1. These coilovers are awesome and will greatly help your handling and ride stance
    2. I have adjusted the rears on other cars without dropping the subframe, but you might have to
    - Clint
    Jul 01 2008
    ^ thanks for your input!
    Ah, gotcha. Yes, set-up for daily driving. On our shop floor (very even surface) the measurement from floor to 12-o'clock on the front fender is about 25½" where we set it for our customers. That's slightly lower then where STaSIS sets it, and our height is still daily drive-able.
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Quote Originally Posted by Dion@Achtuning View Post
    Car looks absolutely killer. Exactly the look I'm going for.
    Are those 18" or 19" RS4 wheels and is that roughly the same stance Stasis ships this kit with, or is that lower?
    I'm in the same boat as the post from NY. I'm in New England and this is my daily driver.
    Jul 01 2008
    ^ That height is our 25½"-from-fender-to-ground height, the typical stance we select. That car is running our 19x8.5" (38mm offset) Hartmann RS4-252M with 235/35-19 Dunlop Sport Maxx tires.
    2004 A4
    Central Jersey
    How would you firm them up?
    Jul 01 2008
    With one of these...
    Instructions (in English) are provided with your kit which describes the procedure on damping adjustment. You can also review those instructions by clicking on the B6/B7 Streetsport Installation guide found at the link below:
    http://www.stasisengineering.com/ins...tructions.aspx
    May 24 2007
    Southern California
    I want these wheels BAD!
    Kyle
    2.0L Revo GTRS Eliminator
    2004 A4
    Central Jersey
    Is this a different shock absorber that comes separately or with the kit?
    Jul 01 2008
    I posted that picture (thanks google) to show the white plastic adjustment thingy at the top of that strut to show what's used to make those damping adjustments (up front).
    2004 A4
    Central Jersey
    Does the white thing adjust the dampening by turning it? How come I can't see a white thing on the picture of the shocks?
    Jul 01 2008
    Yes.
    Because it's not in the picture... It does come with your kit though.
    Established Member Two Rings TREE4309's Avatar
    Aug 11 2004
    Atlanta, GA
    Didn't these used to be $995? Why the huge price increase?
    2002 Ming Blue Audi A4 1.8t Quattro.Manual.Xenon.Sport
    Exterior - 19" BBS CH / Painted lowers / DIY Ultrasport front lip / S4 grilles / S4 door blades / S4 trunk spoiler / S4 Bi-xenon ecodes / Hoen xenon-match fog lights / debadged
    Interior - Neuspeed Short Shifter / XM Commander / Denison Icelink / Audi Sport All-Weather Floormats
    Performance - Revo software / TT225 Injectors / Dual Side-Mount Intercoolers / APR Exhaust / ER Testpipe / APR Snubmount / H-Sport S4 sway bars / JetJockey TIP
    Jul 01 2008
    Quote Originally Posted by TREE4309 View Post
    $995 was a sale price we ran when list prices were just under $1100. STaSIS has raised the prices on these kits due to increased costs to make the kit (thank Koni for that one) so subsequently, our list price went up as well.
    We made an effort to let everyone know to get in on those sale prices while they lasted...
    2004 A4
    Central Jersey
    Ok because I have the STaSIS Streetsport Coilover kit and I bought it from you guys over a year ago.... Mine DID NOT come with that white adjustment knob... Is there a way to order it separate? My suspension is very soft and I want to firm it up as much as it can go.. but I can't find directions nor a tool that I could adjust the dampening. It doesn't even say so in the link posted above..... What could I do?
    Jul 01 2008
    Absolutely I can send you one!! Next time, just be a bit more direct with your questions - I probably could've gotten one out to you by now...
    Send us an email with your request and provide your full name in that email so we can look up order history and get a new package sent your way.
    Jul 01 2008
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    do you guys have any specials for the B5?
    TEAM|AXION
    Jul 01 2008
    Jul 01 2008
    Jul 01 2008
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    are you guys going to be offering anything better than free shipping?
    Jul 01 2008
    Not at this time.
    Jul 01 2008
    This just in from STāSIS Engineering!!
    Our customers have put faith in Achtuning and the products we support. This has resulted in Achtuning being named the top sales distributor for STāSIS Engineering world-wide for 2008!! We thank everyone for their continued support and hope to continue our role as the number one STāSIS Engineering dealer.
