    May 22 2008
    BUffalo/Cleveland
    cold weather problems with my A6
    I have an 96 audi a6. Since the cold weather has started up, my engine has been running horribly. When it first starts up, there is barely if any throttle response, and the engine sounds like it is skipping until it warms up.
    I have a corvette that sounded and ran close to what my audi is doing, but it needed a coil pack. I know it is not a coil pack, because since our weather has warmed up in the last few days (to about 65) the car runs like it is brand new.
    My only thoughts so far is maybe something with the air intake, thottle body, or a map sensor
    Any thoughts?
    wally
    Apr 18 2007
    ny
    Re: cold weather problems with my A6
    Could be a few things like coil packs, plugs, clogged throttle body, vacum leak. I would suspect the plugs and coil packs though. Take out a few spark plugs and see what they look like.
    Aug 27 2008
    lincoln nebraska
    probably shouldn't be revving it much when it just starts, but when its cold the ecu goes into a fuel enrichmnt mode, much like a manual choke until the engine warms up.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    iirc older A6s (at least older C5) have throttle body issues in cold (freezing) weather
    ~ there was even a recall for it
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 05 2008
    St Louis, MO
    You could have bad sparkplug wires. You can check them with an ohm meter. Sometimes they get damaged by pulling them off of the sparkplugs the wrong way, by the wire. There are tools available for pulling on the boots. Also, if you use silicon dielectric grease on the boots, they won't get stuck to the plugs.
    You could also have a plugged fuel filter. You could have water in your fuel, so try putting fuel deicer in your gas tank.
