Results 1 to 8 of 8
    Senior Member Two Rings Phantom2.0T's Avatar
    Mar 29 2008
    B7 Ti-Pack A4
    CA/MD
    Daytime Running Light Replacement?
    I was wondering if there are any replacement lights for the Daytime running lights (DRL). I have Bi-Xenon lights and I wanted them to match the rest of my lights similar to the Xenon match Titanium bulbs.
    http://www.hoen-usa.com/ti.htm
    This was the only thread I found, but these will most likely set off a bulb out warning on the DIS. I was just looking for a set of bulbs that are plug and play. Any suggestions?
    http://www.audizine.com/forum/showth...ng+light+bulbs
    Senior Member Two Rings cfujikawa's Avatar
    Feb 04 2008
    Re: Daytime Running Light Replacement?
    i have piaa 1156 xtreme whites. not quite xenon match, but way whiter than the stock. be careful when you install. i had one bulb that was not locked in all the way. it started to sag and the bulb was touching the housing. did a little melting of the housing and burn marks on the bulb socket, but nothing major. glad i caught it when i did. but since then, i've gotten a bit paranoid, so i turned the drl's off.
    either way, my buttafuoco led citylights look awesome, so i've made it a habit to just turn those on when i start up the car instead of the drl's.
    : 2017 Daytona Gray Pearl Q5 2.0T Premium Plus / Tech / Sport / 20" Rim Pkg :
    : 2007 Silver Acura TL Type-S :
    : 2013 VW Golf 4-Door TDI : *gone*
    : 2006 Quartz Gray A4 2.0T Quattro S-Line Tiptronic : *gone*
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Quote Originally Posted by cfujikawa View Post
    pic ?
    buttafuocco?
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Feb 04 2008
    yeah, check out the thread eMacPaul linked.
    Buttafuoco is a member on here that did us a great service by custom fabricating a plug-n-play LED citylight solution (prior to those zizi ones being sold by ECS tuning). he did a one-time-only deal for us on here, and his lights work without any problems whatsoever. never heard anyone complain about his lights, expect for those complaining about the price... but hey, considering the problems people are having with other "plug-n-play LED lights", i think they were well worth it!
    Mar 29 2008
    B7 Ti-Pack A4
    CA/MD
    Thanks a lot for the information guys. I just ordered my PIAA lights!!!
    Senior Member Two Rings Richardesty's Avatar
    Sep 07 2008
    Audi A4 Sline Quattro 2.0 Tdi
    Lincoln, United Kingdom
    Quote Originally Posted by Phantom2.0T View Post
    Just make sure you've got the live pin at the bottom of the bulb well sprung up, cos the solder at the bottom of the bulb can get hot, melts and then if the live connector isn't properly sprung the connection is lost and your car can read that the bulb is out.....and you have to take it all apart to do as I've said
    I'm replacing my PIAA's with some nice bright led's tomorrow afternoon.....
    I've always said - "One day I'll be able to afford a BMW, and when that day comes I'm gonna buy an Audi"
    Made in Germany - Modified in England
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Are there any LED replacements that don't get a "bulb out" error? Can this be removed via Vag com?
