Results 1 to 13 of 13
    Senior Member Three Rings akarol's Avatar
    May 09 2008
    2003 Audi A4 3.0 Cabriolet
    Orlando, FL
    Synthetic Oil Questions
    Hey guys,
    I'm due for another oil change. I'm the type of guy that would rather let the dealerships handle it since my time and confidence are pretty sparse. I have been going to Audi until now and using their synthetic oil. However, they're pretty far from my house and quite a hassle to get to. I was wondering if the nearby Volkswagen dealership will use the same oil. Audi told me their oil is a custom derivative of the Castrol Syntec oil specific for Audis, but perhaps that includes Volks?! I remember calling a while back and learning that the weight of their oil differed. Is that weird?
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Re: Synthetic Oil Questions
    I wouldn't worry too much about what kind of synthetic you use. It's probably just another way for the stealership to convince you to pay them $90 for an oil change. Indy shops are fine as long as you trust them.
    -Matt
    FCDT Member #1
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    don't go to oil change shops where all the techs look like high school kids.
    Senior Member Three Rings outkasta4's Avatar
    Dec 26 2004
    96 A4 2.8, 02 A4 1.8t
    central coast,CA.
    I wouldnt worry about it, its probably even cheaper at the vw dealership. I know that where I live the audi dealer charges a lot more for the same parts the vw dealer has
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    change your oil yourself... takes 30 minutes.
    synthetic oil - castrol, mobile 1, whatevs.
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by outkasta4 View Post
    I where I live the audi dealer charges a lot more for the same parts the vw dealer has
    My local VW dealer recently stopped cross referencing parts bcs they said Audi dealerships were complaining about the loss of business... go figure they think they got us over a barrel thank goodness for the Internet.
    After my car got off the free scheduled maintenance I would buy my own synthetic oil and take it to an independent who would charge $15 to perform the job. Then one day I needed to get the job done and I couldn't wait. Quick lube raped me $45+ with my own oil. Next time I bought me some ramps and an oil pan for $45 and then have done my oil changes 5 times now. Its good to know u've done the job urself and then know:
    1) The oil's in there
    2) Not overfilled
    3) Oil filter not overtightened/loose
    4) Oil drain bolt not overtightened/loose
    5) Fresh washer on the oil drain bolt.
    My oil of choice is Royal Purple
    I get my washers and oilfilters from ECSTuning.com ... but then this is just me
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    lol, cross reference before you get there :P Screw Audi dealership prices, if they want to charge more for the same thing, they SHOULD lose business.
    I agree fully on doing you own oil. plus the old stuff you can just take to the quick change shops and they dispose of it for you.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Dec 25 2004
    Earth
    I've DIY changed my own since day 1! (nearest stealership 3+ hours away)
    43,000 miles later, all is well!
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    yeah i do all my own oil changes its dirt easy..ive been using mobil 1 5w-30 and 0w-40 but im going to switch to castrol
    Dec 25 2004
    Earth
    IMO, any name brand syhthetic oil of proper grade, changed at regular intervals, will do fine in our street driven engines ;o)
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    vw dealership should be fine. and the larger oil filter is the same one they use for passat and is cheaper than the audi dealership. i buy my own oil and then have them do it sometimes.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Veteran Member Three Rings teg2audi's Avatar
    Apr 23 2008
    Portland, OR
    Quote Originally Posted by MikTip View Post
    I've been changing my own from day one with the same set up as above. Order bulk filters from ecs or somewhere and you're good. Just did mine this past weekend and it takes about 30 minutes but that's mainly because i take my time and always screw around with the plastic skid pieces the never align right the first time. Also put some new plugs in as well. I don't understand how people pay dealerships to do this type of stuff when it's so easy and i only spend 35 bucks. NEVER take your audi to the quick lube places they will rip you off and they do shit work.
    Black 04 Audi A4 1.8t
    APR Stage 2+, Koni FSD/Eibach, OEM USP Wheels
    Member # 15 of Coalition of The OEM+ Audi Owners.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    go to Chris
    dirtybrd is his screen name. get the oil and filter yourself and bring it to him!
    you guys are both in orlando FL, not sure how far away from each other though
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
