Results 1 to 11 of 11
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Big maintenance time!
    Ok so winter is on its way and my car is in some need of TLC! before snow time, first off my brake waring light is on and since summer i have had the winshield fluid waring light on due to the fact that my bottle is cracked, so thats on the list...now back to the brakes, im in need of front pads and rotors, im looking for crossdrilled and slotted rotors...ive see upgrades on ECS , which pads and crossdrilled rotors do you guys like, also the car now has about 87K miles on it, and i think its time for a control arm kit, and sways, the car at times feels "unstable" i guess, so i don't think the control arms are working properly, whats a sign for bad control arms?....so in a nut sell what im asking is.
    1. Which Brakes and pads do you like...no more OEM crap for me they don't last.
    2. Which control arm kit (and i see the ones in the forums)....and whats a sign of bad control arms?
    3. H&R or Hotchkis sways?
    4. what needs to be done to replace a winshield fluid reservoir?
    2004 Audi A6 2.7T
    Established Member Two Rings 2000 A6 2.7t 6m's Avatar
    Jul 27 2007
    PA
    Re: Big maintenance time!
    1) I went with "Adam's Infamous Rotors" group buy for dimpled/slotted rotors, and got Hawk HPS pads, I've been very happy with the combo.
    2+3 - No experience here.
    4) Not too difficult, part of the ABS replacement instructions. Module Masters has a video how to on their site:
    http://modulemaster.com/en/Audi/A6_info.php
    Click for Photo Album
    Upgrades:
    APR 93 ECU -=- H&R Coilovers -=- H-Sport Swaybars -=- VMR B7 RS4 Reps in Onyx Black -=- Upgraded Sound System
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Since you are planning to do 19's I would get a BBK. Otherwise the stock rotor will look tinny with 19's..
    Febi-Bilstein 12pc Adjustable Control Arm kits!
    Hotchkis... I love mine..
    Get TB done too..
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
    Aug 27 2008
    lincoln nebraska
    im in the same boat, but im also doing a timing belt.
    for brakes I seen a popular upgrade is the a8 caliper/rotor. have you seen any info on this yet?
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    1.) Went with stock until I can get other stuff done. Will go with a Wilwood kit after I'm done on the engine.
    2.) I got the Febi kit, very happy with it. Wish they had the adjustable arms out when I bought it, though.
    3.) Hotchkis.
    4.) Haven't had to deal with that yet.
    Mar 30 2008
    Pittsburgh
    thanks guys, and VJ and Kelvin , i got my timing belt and water pump and alternator done at 65K miles almost a year ago :) hehe
    and kelvin , i have seen the A8 upgrade, but there isn't much info on it, i just want drilled rotors , better looks and should last longer.
    And VJ with bbs lm rep's you wont even see much of the brakes, so no worries.
    2004 Audi A6 2.7T
    Aug 27 2008
    lincoln nebraska
    I know the reason they 'upgrade' to a8's id the rotor diameter both front and rear are larger than an a6. I think they can be picked up fairly cheap too...
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    hey Frank here is my 2 cents
    1- unless you have $ to do a BBK, I would get OEM rotors or like rotors and avoid drilled ones. They will warp eAsier and potentially cause vibrations as was the case with my Brembo cross drilled rotors. And to be honest performance gain is so minimal that it is not worth he price premium IMO. Instead just get better pads, I love my Hawks HPS. AND spend a little $ on SS brake lines which will improve pedal feel and fade during mountain runs for example. At the same time upgrade your fluid to the blue racing one.
    3- I think both are good products but I hear HSport are better and certainly are more popular for our cars IMO. I love mine.
    Hope it helps
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Apr 05 2007
    I'm probably picking up a 2000 Avant this weekend and need to do this (except for sways).
    1. OEM rotors and PBR/Axxis Deluxe pads. I only use pbr deluxe as they're low dust, grip well and last a long time. They've never failed me
    1a. make sure to replace, or better yet, upgrade your caliper bushings. On my old Passat (a6 chassis) the Tyrolsport did wonders for brake feel. No more flex, just solid. It's the first upgrade I will do to the A6: http://www.tyrolsport.com/index.php?...=124&parent=64
    2. I would buy the control arm kit from PureMS or Blauparts. Both I hear are good kits and both Febi-Biltstein I believe
    3. I've heard good things about both. I'd choose based on price.
    4. When i fixed my ABS module on my old passat I had remove the windshield washer reservoir. All that was required was removing the front driver side wheel well liner -- this gives you all the access you need. Just 3 easy to reach bolts I believe.
    Mar 30 2008
    Pittsburgh
    thanks guys, good deal.
    2004 Audi A6 2.7T
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Frank -
    Did you decide on color for wheels yet?
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
