Results 1 to 15 of 15
    Account Terminated One Ring
    Nov 06 2008
    Michigan
    explain are pistons the guy at my work says they are cut out of cast
    explain
    Registered Member Two Rings
    Jan 09 2008
    2001.5 s4
    Re: explain are pistons the guy at my work says they are cut out of cast
    english?
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Pistons are cast or forged. A cast piston is formed using molten aluminum into a mold which leaves the unit porous (hole pockets). A forged piston is formed by taking a piece of aluminum and dropping a one to two ton forged press unto it to increase the aluminum tensile strength. The molecules are closer together versus the cast unit. Lastly, the piston is machined nowadays on a CNC machine to cut the piston.
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    this post is terrible
    2010 Brilliant Black/Magma Red S4
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    My explanation or the OP's post?
    2001.5 Audi S4 VRT
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Big Boost View Post
    no your response is the only thing that makes sense.lol good explanation.
    Jan 09 2008
    2001.5 s4
    Hey, I thought mine made sense
    Jan 14 2008
    Carlisle, PA
    the op's post. haha
    Veteran Member Four Rings imola's Avatar
    May 23 2007
    The guy at cast out of work does not understand what pistons are cut is what says
    Oct 29 2005
    10speed
    San Francisco, CA
    it took me a few seconds, but I figured it out... The "are" is retarded and misleading
    He meant to say
    " The guy at my work says OUR pistons are cast, is this correct?"
    - Clint
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    will one of the moderators please delete this thread?
    Quote Originally Posted by imola View Post
    I hope your joking because this makes no sense either, lol
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    AudiA4_20T is probably right. Imola LMAO
    May 23 2007
    Quote Originally Posted by wdbdy2000s4 View Post
    lol what? understood no?
    Oct 24 2008
    Louisville, Ky
    They are forged.
