Results 1 to 13 of 13
Thread: fuel filter DIY
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    fuel filter DIY
    is there such a thing?
    <3
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    Re: fuel filter DIY
    search
    "my other ride is your daughter"
    Apr 17 2008
    Chapel Hill, NC
    Apr 02 2007
    Re: fuel filter DIY
    Thanks man... I did a preliminary search and then also searched on a4mods.com but couldn't find one... Spent another 10 minutes searching and came up with a few.
    Do you know if the fuel pump should be replaced at the same time? or if i should wait for symptoms... just turned 70k
    Taylor A. Maneri
    tamaneri (AIM)
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Re: fuel filter DIY
    How come the forum admins don't put a bunch of these DIY's in the DIY secton of the forums?
    -Matt
    FCDT Member #1
    Apr 02 2007
    Re: fuel filter DIY
    i often wonder the same!
    Taylor A. Maneri
    tamaneri (AIM)
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Re: fuel filter DIY
    Quote Originally Posted by tamaneri View Post
    No need to do the pump. As long as you're changing the filter, you'll be ok. I just did mine a couple of days ago and I know AudiProtein just did his a few days back also. The clips on the hoses are a real PITA and they're very brittle so be careful.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Apr 02 2007
    Re: fuel filter DIY
    Alright thanks Undisputed. Scheduled to take care of this on saturday!
    Taylor A. Maneri
    tamaneri (AIM)
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Re: fuel filter DIY
    before you do this, check your VIN against the recalls. there's a currect recall for the fuel pump but only for specific model years. i had mine replaced last yeat for free they will replace your filter too.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Apr 02 2007
    Re: fuel filter DIY
    where can i find out?
    I'm rockin' an '03 1.8TQ 5speed
    Taylor A. Maneri
    tamaneri (AIM)
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Re: fuel filter DIY
    I believe MY 2003 was the year the recall applied to.
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Re: fuel filter DIY
    im pretty sure 2003 was the year for the problems.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Apr 23 2007
    Re: fuel filter DIY
    Here you go. You should be covered if you're 2003, mine is too, However i remember dealer was telling me you still had to fall in under a certain VIN range.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
