Finaly got me a A3 airbag to go with my new A3 Sline steering wheel.
Bought the wheel thinking I could reuse my 3 spoke airbag from my A4...........No go!
Here is the original wheel:
Start with unscrewing the 2 torx in the back of the wheel with torx t25 bits, you have to turn the wheel to be able to reach the screws so don't disconnect the battery just yet:
No disconnect the battery.
When this is done the airbag is now loose:
Now take you newly purchased M12:
And unscrew the center bolt:
Now make a mark on the center steering thing to indicate center of the wheel and remove it:
Don't touch anything here:
No take your new wheel and mount it on the same place as you marked earlier:
An then you should mount your new airbag............ Different plugs...Looked identical, but when i looked inside the wiring was different.
I decided to change the cables from the a4 airbag over to the new a3 airbag. That worked great. I hope....................:
Then connect the airbag and put it in place. Connect the battery and start your car from the passenger side(Just incase it EXPLODES).
Turn the wheel so that you can rescrew the two torx in the back and you are good to go!
Hope people can use this.
I take no responsibility for any damage or anything that might happen because of people following this writeup.I give no guarantee that this will work on your car........Everything is on you. :)
